Go to Post We can build it... we have the technology...better than it was before... Better...stronger...faster.... more PINK - Barry Bonzack [more]
Go Back   Chief Delphi > FIRST > Career
Unread 24-01-2013, 17:18
LK Peter LK Peter is offline
FRC #3871
LK Peter is an unknown quantity at this point
Is it possible to have a static IP Address for programing?
My FIRST Robotics Team is trying to program the robot, but we keep having to manually change our IP Address back. Is there any way we can use a static IP Address or keep the IP Address from changing?
Unread 24-01-2013, 17:34
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Re: Is it possible to have a static IP Address for programing?
I would suggest posting this in the programming forum.
Unread 24-01-2013, 17:37
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Your computer address can be any address on the subnet. Driver station seems to want 10.xx.xx.nn. Where xx.xx is your team number & nn is 255>nn>4.
For competitions only the driver station nn has to be .5. Extra or programing computer is generally .6
If the DHCP is turned in your router the address it give should work. You can set a static IP address. The procedure varies depending which version windows you are running. The issue here you have to set back to dynamic for other networks.
