Go to Post It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen. - Andy Baker [more]
Unread 24-01-2013, 20:59
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
pic: 2012 Wiring Panel - 1619
Unread 24-01-2013, 21:01
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: pic: 2012 Wiring Panel - 1619
That is beautiful!
What is the wire track stuff that you are routing your wires in? It is so clean and elegant.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 24-01-2013, 21:09
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Originally Posted by ehfeinberg View Post
That is beautiful!
Try wire duct at McMaster It does make electronics look a lot neater.
Unread 24-01-2013, 21:58
daneelshof's Avatar
Programming Mentor
Yep, that's a good place to source it. I believe we used Panduit brand wire duct, but it's all pretty much equivalent. It works well for us because we can easily add or remove wires later and it still looks clean.
Unread 24-01-2013, 22:28
Mugurussa675 Mugurussa675 is offline
FRC #0675
Team Role: Driver
Mugurussa675 is on a distinguished road
Such clean wiring. I wish i wasn't the only one on my team who could wire like this.
FRC Team 675
Drive team
Team Leader
Manufacturing Leader
Unread 24-01-2013, 23:33
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Looks awesome.
I have to ask though, where did you get the bender attatchment for the analog breakout board?
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 25-01-2013, 11:47
Dgk518's Avatar
Dgk518 Dgk518 is offline
AKA: Danny Kosty
FRC #0222 (Tigertrons)
Team Role: CAD
Dgk518 is an unknown quantity at this point
Originally Posted by Toa Circuit View Post
Looks awesome.
Here's one that i found, might be a little boxier but it gets the job done
http://www.l-com.com/item.aspx?id=8814
2012 Chestnut Hill District Finalist (Thanks 4342 and 2180)
2012 Mount Olive District Champs (Thanks 25 and 3929)
2013 Mount Olive District Champs (Thanks 11 and 3340)
2013 MAR Championship Finalist (Thanks 1640, 2590, and 2729)
2014 Mount Olive Finalist (Thanks to 1403 and 4285)
Unread 14-02-2013, 17:40
ericbanker ericbanker is offline
FRC #1208 (The Metool Brigade)
Team Role: Electrical
ericbanker is an unknown quantity at this point
Our team decided to try this as well using the pre-made adapter you linked. Unfortunately, it turns the connector in the opposite orientation as the one you made so we can't use it on our bot. I guess I should have done a bit more research before ordering.
On the bright side, I was able to completely disassemble the adapter, and should be able to soldier it back together with a spare ribbon cable.
Unread 25-01-2013, 12:33
daneelshof's Avatar
Programming Mentor
Looks awesome.
We built that ourselves. I believe it's just two standard DB connectors wired straight through and then covered with heat shrink. The lid of our control system was too shallow to use the standard connection.
Unread 25-01-2013, 13:26
Thaddeus Maximus
AKA: Thad Hughes
Oh, nice! I saw this and thought that we might use something like this cause we're cramped on space too.
Webpage
Unread 29-01-2013, 14:59
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Thumbs up Re: pic: 2012 Wiring Panel - 1619
This is so beautiful! I could cry!
"This must be what going insane feels like."-Simon Tam, Firefly
