Go to Post Seats are seats, we're all watching the same thing. - katiyeh07 [more]
Unread 01-25-2013, 04:19 PM
1757 1757 is offline
FRC #1757
1757 is an unknown quantity at this point
Camera not showing up in dashboard?
I am not exactly sure how to get our axis camera image to show up on dashboard.
The camera works fine when you view the ip like this in chrome. It also shows up with the current mbps and and fps. It also displays this line on occasion.
\>>>>ERROR: S_errno_EINPROGRESS (0x00000044): Failed to connect to the camera ...in CreateCameraSocket() in C:/WindRiver/workspace/WPILib/Vision/AxisCameraParams.cpp at line 457
I'm currently only using AxisCamera camera = .getInstance(); at the beginning of my code. Please help.
Unread 01-26-2013, 02:09 PM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Camera not showing up in dashboard?
Take a look at this page in the documentation. It describes how to view the Axis camera on the SmartDashboard.
http://wpilib.screenstepslive.com/s/...sion-installer
Brad
Brad Miller
Robotics Resource Center
Unread 01-27-2013, 01:45 PM
llung llung is offline
FRC #4048
llung is an unknown quantity at this point
We appear to be having the same problem; we followed the steps to set up the SmartDashboard, and it only says 'NO CONNECTION'. Our camera doesn't work with the ordinary dashboard either (although there, it does show the FPS as if it were actually doing something). We've made sure that it's at the correct IP address, configured for anonymous viewing, etc, and it does work viewing in browser. We also get the same error message as seen above; the .cpp file it references does not appear to exist in our system anywhere. Any help at all would be greatly appreciated; if there is any sort of log file or configuration settings, etcetera that it would help to post, please let us know.
Unread 01-29-2013, 06:11 PM
team4254 team4254 is offline
FRC #4254
team4254 is an unknown quantity at this point
I know this is of no help whatsoever but we are having the same exact problem as well. SAME EXACT
Unread 02-02-2013, 02:38 PM
FRC #4048
We appear to have solved our problem by reimaging the Classmate with this year's image. Hope that this works for others.
P.S: Reimaging requires activating Windows, which there's no mention of on usfirst.org this year; if you, like us, don't have an internet connection on the Classmate, you can do it via phone.
Best of luck,
- Team 4048
Unread 02-02-2013, 04:42 PM
kylevedder kylevedder is offline
Programmer
AKA: Kyle Vedder
FRC #0467 (Shrewsbury Colonials)
kylevedder is an unknown quantity at this point
We experienced a similar problem. The fix we found was to do a complete uninstall of the driverstation software and completely re-install this year's software from the disk issued to you. Also, make sure when you are done you click the enable button under the white box where the camera goes. We found this fix in some obscure document on the USFirst / WPI documentation website telling us the uninstall was optional.
Note: This does not require a complete re-image, just a re-install of software, so hopefully this will save you some time.
Good Luck!
