Go to Post Like a wizard, Car Nack is never late. He always arrives precisely when he meets you. - EricH [more]
Unread 25-01-2013, 16:26
sandbag747 sandbag747 is offline
FTC #3603 (Reed City Cyber Coyotes)
sandbag747 is an unknown quantity at this point
Making Telescopic Arm
Our team was at a loss for trying to make a telescopic arm and I thought of coming here but wasn't exactly sure where to put it. Does anybody have any good ideas for making a telescopic arm for like climbing or know of any videos or stuff like that? Thanks in advance
Unread 25-01-2013, 16:32
RyanB RyanB is offline
FRC #0360
RyanB is an unknown quantity at this point
Re: Making Telescopic Arm
Depending oh how you power the arms something as simple as increasing diameters of PVC pipe can make a telescoping arm. If you look at 2011 robots there are some great examples of vertically extending arms.
Unread 25-01-2013, 16:40
We don't even know how to move the segments if we tried that, how would you power it? My thought was pneumatic but we need it shorter thank the full length
Unread 25-01-2013, 20:04
Use a shorter pneumatic piston. The only restriction is that the piston (cylinder) be rated to 125 psi.
Also, look at some of 254's cable-powered lifts, for example in 2007. That takes a motor, a winch, and some cable or rope, along with pulleys. A little more work, perhaps, but infinite positions within the range of motion.
Unread 25-01-2013, 20:10
Chris is me's Avatar
AKA: Pinecone
If its single stage (it should be), a leadscrew and Delrin sliders should get you started. 2016's 2011 robot is a good example that at one point we considered emulating.
Unread 25-01-2013, 20:20
pfreivald's Avatar
AKA: Patrick Freivald
We strongly considered emulating 1551's Regional-winning arm from 2010. Oh, and then we did that, with some modifications, because, well, emulating a prior success seemed like a good idea.
We used Bosch Rexroth extruded aluminum and delrin sliders on an aluminum carriage, on a fast multi-start screw driven by a CIM. This year we're going with two CIMs and some constant-force springs (because we learned some things from 2010!) The drive mechanism is *heavy*, but we think it's necessary to ensure a stable, smooth, efficient climb.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 26-01-2013, 21:26
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
We're making a 4 stage telescopic arm. The base is 5x5 aluminum square tubing, the next stage is 4x4, then 3x3 and 2x2. I'd suggest searching for images of telehandlers for inspiration. JLG, Genie, and several others make a lot of machines like this. Your local Sunbelt or United rental may even let you analyze one up close.
Unread 26-01-2013, 21:41
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
As Chris said, we have used the lead screw three years in a row for different functions...
It is easy and effective for the right function.
If you have any questions on building a telescoping arm reach out to me and I can share the appropriate details.
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
Unread 26-01-2013, 22:46
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Back to basics.
Look at this link from Andy at AndyMark. It has a nice diagram of how a telescoping system works.
http://d1pytrrjwm20z9.cloudfront.net...atorDesign.pdf
You can put the tubes inside each other or slide them along side each other, either way will work.
Here is an old CD thread that might help, also,
http://www.chiefdelphi.com/forums/sh...t=manipulators
Finally, many pop-up campers use cable lift systems. Here is a link to how they work.
ttp://www.customcylindersintinc.com/understanding_camping_trailers_roof_lift_systems.h tm
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
