Go to Post It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work. - Cory [more]
Unread 26-01-2013, 15:50
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Pulley System Gear Reduction Question
We are a little stuck looking for a part.....
For our shooter our drive motors are not going fast enough and thus we need to change the gear ratio. We are driving the 8" pneumatic wheels with the pulley system provided in the KOP. Would anyone out there know where to purchase bigger and smaller belt gear? We have looked on AndyMark some but wondering if there is a better source or a link we can go to.
Thanks
jalmos
Unread 26-01-2013, 17:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Pulley System Gear Reduction Question
Each team can get additional Gates sprockets and belts for free. There is a voucher in the kit of parts that tells you how.
When used with toothed belts, those round things are called sprockets not pulleys. FYI only.
Unread 28-01-2013, 16:24
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Pulley is the term used by Gates and suppliers. We buy 5mm GT2 pulleys from SDP-SI (http://sdp-si.com/). Just make sure the item is in stock... or else you may not see it until June.
Unread 28-01-2013, 17:22
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
What are you using for motors/transmissions?
Using a CIM direct drive our shooter works fine.
It also works using a 775/18 motor with CIM-u-lator transmission.
In fact, it shot better going a little slower.
We are using 8" AM pneumatic wheels.
