Go to Post Only think of Gracious Professionalism as a standard to work toward personally. Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 28-01-2013, 19:51
momoJr0 momoJr0 is offline
FRC #4209
momoJr0 is an unknown quantity at this point
Speed Controllers Not Working
We are having an awkward issue with our speed controllers.
Our controllers will work as expected until we pass them a value below a certain threshold, at which point they no longer work. For example, this is what happens with the following code:
drive.tankDrive(1,1); //Works normally
drive.tankDrive(.5,.5); //Stops motors. Expected, as they probably just do not have enough voltage to run.
drive.tankDrive(1,1); //Motors no longer run. 0V out of speed controllers.
Once the motors stop we must disenable and reenable to get them to run again.
Team code can be found at:
https://github.com/lwague2/Team4209/...4209Robot.java
NOTE: Due to the way our robot is built and a lack of splitter cables, we have two 2-wheel RobotDrives that we simply pass like values. This seems works as expected and does not seem to be the source of the problem.
Unread 30-01-2013, 16:40
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: Speed Controllers Not Working
From what I can tell, you're still using the 2012 plugins which won't work very well. This year, the update URL is different. Also, the new version doesn't have the teleop, autonomous, or disabled continuous methods, and it has a test mode. Also you shouldn't have to touch the watchdog.
