hii guys we are rookie team and i dont know wats wrong with our cRIO Imaging tool. when i scan it work everything fine but its taking so long so long to reboot idk that's good or not but i need help with that please.....thank you
Re: cRIO problem
What is taking a long time to reboot? The cRio or the Imaging Tool?
Two issues I have had in the past. - Make sure the cRio is plugged in. - Make sure the modules are in the right slot. |
Re: cRIO problem
the imaging tool is good but when is rebooting its talking way too long idk..
Re: cRIO problem
I'm going to be assuming that the imaging tool is taking too long to reboot.
They update the tool, every so often. Check here: http://www.usfirst.org/roboticsprogr...ical-Resources |
Re: cRIO problem
I did update though idk its same thing..
Re: cRIO problem
Boot the cRIO into safe mode by holding the reset button for 5 seconds until the status light stays solid yellow, then try again.
#7
Re: cRIO problem
Have you tried all the troubleshooting steps listed at the bottom of this document?
#8
Re: cRIO problem
OK
#9
Re: cRIO problem
Any other ideas??
#10
Re: cRIO problem
You've tried disabling all other network adapters, tried with and without a switch in-between, and checked that the netmask is 255.255.255.0 as detailed by the page I linked to?
#11
Re: cRIO problem
ok i will try that thanx...
#12
Re: cRIO problem
#13
Re: cRIO problem
It does not corrupt the cRIO. It does require a two step imaging (image the cRIO in safe mode, then reimage the cRIO not in safe mode).
#14
Re: cRIO problem
This is incorrect. As was said, it simply does a two step imaging, and the 2013 Imaging Tool will handle that for you. From the user's end, you only need image it as you would were it not in safe mode, and click the dialog to confirm formatting it. In no way does it corrupt the cRIO.
#15
Re: cRIO problem
