Go to Post "I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." -Woodie Flowers - Barry Bonzack [more]
Unread 30-01-2013, 21:45
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
Question LabView Button Problems
I am not sure how to make a bi-directional motor using two separate buttons, Ex. being "button 2 make motor move counter clockwise, and button 3 makes same motor move clockwise.
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 30-01-2013, 21:57
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Post Re: LabView Button Problems
Given two buttons, there are four possibilities you need to handle. Here's a simple truth table that shows them:
Button2    Button3    Result?
F          F          ??
F          T          Go Clockwise
T          F          Go Counter-clockwise
T          T          ??
On the "??" cases, you need to choose whether to do what it was already doing, stop, or some other specific action depending on what makes sense in your mechanism.
Use select VIs (or nested case statements or a select statement in a case statement, depending on what makes the most sense to you) to get the right result for each situation, then feed it to a Motor Set.
Unread 30-01-2013, 23:04
Did my reply the other day not help? Here's one of the better answers you should have been able to find by searching.
