Go to Post I have photos of students working the lathe dressed for a concert! Makes me wish for a formal dress night at robotics. - Mark McLeod [more]
Unread 01-02-2013, 17:11
Cody Burd's Avatar
Cody Burd Cody Burd is offline
FRC #3607 (Technologic)
Cody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to all
Team 3607's 2013 base
Hey, here is our masterpiece so far.
http://s1323.photobucket.com/albums/..._media_sh are
Unread 01-02-2013, 17:29
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Team 3607's 2013 base
A word of advice from someone who learned the hard way, casters are evil!!!
Use them on your robot cart but never use them on your robot.
Unread 01-02-2013, 17:33
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Seconded. If you replace them with an omniwheel, you will be much happier with your performance.
Unread 01-02-2013, 17:38
Cody Burd's Avatar
how are they evil?
Unread 01-02-2013, 17:40
wilsonmw04's Avatar
Coach
Originally Posted by Cody Burd View Post
how are they evil?
because they are independent and swivel. You will never be able to put the robot where you want it to be. there will always be play in the position of the robot from side to side and front to back.
Unread 01-02-2013, 17:43
Cody Burd's Avatar
We decided that we want it to do that.
Unread 01-02-2013, 17:45
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Lack of control was what you decided on???
We did that our rookie year at my old school. Never again!
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
If you've ever tried to push a really heavy shopping cart, you may have some experience with the issue. If you've got some weights, load up your frame to 150lbs, put it on carpet and try pushing it around from the rear where your drive wheels are. You'll see what we're talking about.
The casters will not always be aligned with the direction you want to move next. They may not be aligned in the same direction as each other. The swiveling action that wilsonmw04 refers to will cause your robot to not go straight when you try to drive forward, but start to veer off to the side instead. This makes the robot very unpredictable and hard to control.
Omnis are a great solution.
Unread 01-02-2013, 17:52
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
This off-season we did freshmen/ team training which involved splitting the team into 2 and challenging them to build a robot to navigate a obstacle course. One team did the same set up as you, while the other did a 6 wheel tank drive. The set up similar to yours could NOT drive straight, and every time it tried to go over even the tiniest bump (about a quarter inch at most), it would veer towards a different direction. YOU WILL GET NO CONTROL!!!
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 01-02-2013, 17:56
Cody Burd's Avatar
yea I see what you mean.
Unread 01-02-2013, 18:01
Cody Burd's Avatar
Yea, We just pushed it and you were right. Our drive is to have 2 wheel back powered with an independent front. Will the Omnis do ok with that
Unread 01-02-2013, 18:03
Nuttyman54's Avatar
Mentor, Tactician
Omnis will be significantly better, and would be pretty easy to retrofit on to your current chassis. If you can find a way to run some chain from the back wheels to the Omnis in the front, that will also help a lot, and won't hurt your turning ability at all.
Unread 01-02-2013, 18:20
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Just throwing in another "Our team made the same mistake" comment. Caster wheels are evil. Eventually we chucked that idea for a relatively "better" drive system.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
