Go to Post I have never seen a coach with a better ability to yell with love. - IndySam [more]
Unread 02-02-2013, 11:15
ShadowBot's Avatar
ShadowBot ShadowBot is offline
FRC #3577
ShadowBot is an unknown quantity at this point
Loop Starving Robot Drive
First off I am a relatively new programmer in LabVIEW. Our robot is running a four-motor tank drive. I have been having problems when driving the robot, the code cuts and the robot has to be disabled and reenabled in the driver station. This cut only happens when the left joystick is foward and the right joystick is back AND when past 60% power. The other way works fine.
We checked the diagnosis and came up with this error code:
ERROR <Code> -44061 occurred at "RobotDrive" in the VI path: Robot Main.vi
<time>17:15:45 02/1/2013
FRC: The loop that contains RobotDrive is not running fast enough.
This error can occur if the loop contains too much code, or if one or
more other loops are starving the RobotDrive loop.
I have gone through the code and checked everything that might be causing this problem but it continues to occur. Any suggestions of what can I do to fix this?
Unread 02-02-2013, 15:43
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Loop Starving Robot Drive
Can you attach your Teleop code so we can take a look at it? (I'm assuming that this problem is occurring when you are running with Teleop enabled.)
Unread 14-03-2013, 11:47
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
I am having a similar problem and dont know what to do. I have attached our teleop code for review. We dont lose communication but our drive speed is very slow.
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 14-03-2013, 12:54
nekojess nekojess is offline
Controls Surgeon and Diagnostician
AKA: Jessica C
nekojess is an unknown quantity at this point
Is it consistently slow, or kind of jittery? Try seeing if the error console on the driver station says anything.
Try disabling non-drive parts of your code using the Diagram Disable structure. If you do it in sections, you can maybe see which part is the problem. Or at least see which parts aren't the problem.
Unread 14-03-2013, 14:07
mjgard's Avatar
Michael
AKA: Michael Gard
It seems consistently slow. The error we get on the DS is:
<time>23:36:12 03/13/2013
FRC: The loop that contains RobotDrive is not running fast enough. This error can occur if the loop contains too much code, or if one or more other loops are starving the RobotDrive loop.
Michael
FRC 2844
Unread 15-03-2013, 23:45
This answer is probably too late to help, but this is the first time I noticed the thread.
It sounds like your Digital Sidecar is not properly powered with battery voltage from the Power Distribution Board. The -44061 error is probably unrelated to the cutout you're seeing when commanding a turn.
