How to toggle a relay with one button?
I need to turn a relay on and off your one button on the joystick. Much like a toggle button. Could some one give me some sample code?
Re: How to toggle a relay with one button?
Here's a generic button toggle example:
![]() Put one Relay set in the inside True case, the opposite set in the inside False case. |
What are the green arrows?
The green arrow is found on the Programming -> Structures palette.
It's called a Feedback node, and what it does for you is remember the previous value, so the current value can be compared to the previous value. So for the button press the value can be thought of as 0 (false) or 1 (true). That first peculiar little combination is checking to see of the button is going from off (the previous value) to on (the current value), so it's only true the very first time you press the button and won't be true again until the button is release and pressed again. To change the arrow direction once you put it on your block diagram, right-click and choose Change direction. Last edited by Mark McLeod : 02-02-2013 at 12:14. |
How does the arrow become green? I found the arrow, but it is black.
It changes color based on the data type that then gets wired to it.
It's green in the example because a boolean wire got connected to it. So it'll turn green when you wire the button output to it. If you wired an integer to it, then it would turn blue. A floating point number would make it orange instead. |
#7
Thank you very much! It worked
#8
What about false in the outer case structure of?
#9
The outer false case avoids doing anything at all.
That's when the button hasn't been pushed again. The wire just gets passed from the input tunnel right to the output tunnel. Last edited by Mark McLeod : 02-02-2013 at 19:09. |
#10
One of our veteran team members wrote a very simple and effective Toggle vi, which I've attached. Just feed the button signal into the input, then use the output with a select block or case structure to select your relay state.
#11
I was asked to provide a screenshot of what our team's Toggle VI looks like, so here's how it works!
