Go to Post I can follow directions, but if it's not in the directions, I'm lost. - rclothier [more]
Unread 02-02-2013, 13:00
c.claudio c.claudio is offline
FRC #3013
c.claudio is an unknown quantity at this point
How to get VEX Encoder to work with the cRIO?
We decided to use a VEX Encoder to measure our shooter's angle, but we aren't sure how to get the VEX Encoder to work with the cRIO, or if it is even possible.
Our team would appreciate it if you would share a sample code with us, (if possible), and the wiring schematics.
Thank you in advance.
Unread 04-02-2013, 18:00
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Re: How to get VEX Encoder to work with the cRIO?
Well, I honestly do not know if the encoder will read correctly, but go ahead and plug the two cables into the DIO ports on the digital breakout. Here is some basic code to get you started with the coding. You will most likely want to find home using a limit switch in autonomous.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Last edited by blackflame2996 : 04-02-2013 at 18:17. Reason: Added find home function to vi
Unread 04-02-2013, 19:48
FRC #3013
Apparently, our team changed from the VEX Encoder to the AS5145B Magnetic Encoder, will the sample code also interface with it?
Unread 04-02-2013, 22:30
That kind of magnetic encoder is a much more appropriate sensor for reading the angle of a rotating component like an elbow joint or shooter elevation. The usual way to interface with it is to read an analog voltage it provides. Nothing fancy.
