cRio issue
We are trying to configure the cRio but when we go to download the image it says that we do not have card 9403 in slot 2 and cannot deploy runnable labview code. We are able to put the 9403 in another slot and see it but it will not be detected in slot 2. Is there a way to switch which slot the 9403 can be placed in or another solution?
Re: cRio issue
A DIO module in Slot 2 is required by the robot rules. Is there something obviously broken about that slot's connector? If a pin is bent, it's possible to unbend it with a very careful application of force. If that slot is truly broken, you should have it repaired. How old is the cRIO?
Re: cRio issue
While it's probably not competition legal to compete like this, you may be able to image it with it in slot four. I assume it's an eight slot?
