Hi, I'm using a 38kHz ir-LED and receiver module. However, I've had some trouble writing code for them. I think I figured out the receiver module and have wrote most of the code for it. I used a simple DigitalInput class and printed the value. It should be 1 if it doesn't receive anything and 0 if it does, right?
The main problem I've had is making the LED output 38kHz. I'm trying to use a DigitalOutput class, so I wrote this:DigitalOutput *irSender; irSender = new DigitalOutput(2); irSender->Set(true); Can someone please tell me what I am doing wrong? I could really use any advice. Thanks |
Re: Need help with infrared sensor
Why are you using IR?
How is your LED wired? Do you have a picture/diagram?
It is a zx-irm receiver and a zx-irLed light.
![]() ![]() We can make the LED light up but don't know how to get it to flicker at 38 kHz. |
To get it to flicker at any frequency, provide it with that frequency on its input.
What are you trying to do with this sensor? There might be a better way to accomplish it. |
