Go to Post A rule is a rule is a rule. - Cory [more]
Unread 04-02-2013, 20:11
thecakeisalie's Avatar
thecakeisalie thecakeisalie is offline
FRC #0293
thecakeisalie is an unknown quantity at this point
How to create an On/Off button?
While reviewing our shooter code, I figured that the ability to be able to toggle our shooter wheels on/off would be a nice feature to have. However, no matter how hard I tried, I simply could not figure out a way to do this.
The only method that I was able to call upon was just joystickButton.get() since we are using Iterative robot this year.
If it is possible to create an On/Off button, how would it be done?
Unread 04-02-2013, 22:24
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: How to create an On/Off button?
An On/Off button on the dashboard or on your joystick?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 04-02-2013, 22:43
FRC #0293
On the joystick. I would prefer a more physical button.
Unread 04-02-2013, 22:55
AKA: Spencer Lanman
The easiest way would be to save the state as on or off in a boolean or byte variable and then switch it every time the button is pressed.
Pseudo-Code:
if joystick button pressed then
    if lightsAreOn is true then
        //so some stuff
        set lightsAreOn to false
    else
        //do some stuff
        set lightsAreOn to true
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 05-02-2013, 17:48
FRC #0293
That won't work since teleop loops every 20ms, which means one press will equal a lot of Joystick.get()'s.
Unread 05-02-2013, 18:25
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Use the Timer to limit how quickly you can toggle.
double interim = 2; //can only toggle every 2 seconds
double previous = 0;
boolean isOn = false; //state of motors
if(JoystickButton.get()) {
  /*check if interim time has passed since previous check*/
  if(Timer.getFPGATimestamp() - previous >= interim) {
    previous == Timer.getFPGATimestamp();
    if(isOn == true) {
      //change state of motors
      isOn = false;
    } else {
      isOn = true;
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 05-02-2013, 18:38
button1 = GetButton(button1);
if (button1 && ! button1previous) toggle1 = !toggle1;
button1previous = button1;
initialize toggle1 to zero.
Unread 05-02-2013, 20:03
FRC #0293
Thank you. This is exactly what I was looking for but couldn't write myself
I assume that if you wanted to start with the motors running, I would initialize toggle as true?
Unread 05-02-2013, 20:05
Yes. Either that or run the motors when it's false
Unread 05-02-2013, 20:50
AKA: Spencer Lanman
Not if your using the command-based template.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 07-02-2013, 15:50
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
This is code that I wrote and use. Just make all of your buttons AdvancedButton and call
button#.togglePressed(yourCommand);
some variables are protected so that they cant be accessed but u can still extend the class and make your own addition
code
