Go to Post I don't mind being odd...I like to - listen - to Dean Kamen's speeches. They make sense. I don't get to listen to a lot of sense in the world, just a lot of noise. - JaneYoung [more]
Unread 05-02-2013, 16:33
DPG2013 DPG2013 is offline
FRC #4163
DPG2013 is an unknown quantity at this point
WPI cookbpook help
I am kind of new to Java programming and I was looking through the WPI cookbookhere and under the command robot tutorial I saw this:
public class Chassis extends Subsystem {
public static final int LEFT_MOTOR_PORT = 2;
public static final int RIGHT_MOTOR_PORT = 1;
public static final double TURN_AMOUNT = 1.0;
public static final double FORWARD_SPEED = 1.0;
private static Chassis instance = null;
private RobotDrive drive;
public static Chassis getInstance() {
if(instance == null) {
instance = new Chassis();
instance.setDefaultCommand(new DriveWithJoystick());
return instance;
private Chassis() {
drive = new RobotDrive(LEFT_MOTOR_PORT, RIGHT_MOTOR_PORT);
drive.setSafetyEnabled(false); // to simplify explanation (not good practice)
public void straight() {
drive.arcadeDrive(-FORWARD_SPEED, 0.0); // start driving forward
public void turnLeft() {
drive.arcadeDrive(0.0, TURN_AMOUNT); // start turning
public void driveWithJoystick() {
drive.arcadeDrive(OI.getInstance().getJoystick());
I pretty much understand every thing except the instance part. What is a instance and how is it being used here.
Unread 05-02-2013, 18:35
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Re: WPI cookbpook help
A class is the blueprint for an object.
An instance is an object of a class.
Basically what that code is saying is: "Only one instance of Chassis will exist, and it is this one. In order to use it you need to get it from me."
another example: the drive object in that code is an instance of RobotDrive.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 05-02-2013, 19:20
FRC #4163
That makes sense thank you.
