Go to Post Well I have to admit, most of the people on our team are geeks. I think that it's a title of honor considering it might as well be "boss" or "head supervisor" or something along those lines. - Cyberguy34000 [more]
Unread 08-02-2013, 02:52
matthewgkerr matthewgkerr is offline
FRC #4529 (Team Melbourne)
matthewgkerr is an unknown quantity at this point
Creating a board for my electronics
Hi all. This is probably a real basic one. I have created a couple of boards using 2D sketches and the extrude command. I want to use this to lay out my electronics so I can start getting a feel for where everything will go. I have been mating the faces of the parts to the board and constraining the edges with offsets. This all works fine except it is rather clumsy and slow. Also, I'm unsure how to use this same process when mating the Jaguar motor controllers, which has rounded edges. Is there such a thing as an apparent edge?
What I would like to know is what is the quickest workflow for creating a mounting surface and placing parts on that surface? i.e. what process are others using to place the motor controllers (and other parts) on their robot?
Matthew Kerr
Engineering Mentor
Team Melbourne
Victoria Australia
Unread 08-02-2013, 06:35
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: Creating a board for my electronics
Are you talking about CAD/CADD layouts? What software are you using?
You should be able to take the edge-to-edge of one of the flat sides, make objects parallel, space at a set distance, etc. You can also use the center points (sometimes you need to enable the software to show center points) of round objects and use them to line up from the edges of your board.
Have you tried looking at "[CADD software name here] dimensioning and layout" or a similar query on YouTube?
Unread 09-02-2013, 04:09
I am using Inventor. What I'm doing is trying to understand how to best create a board to fix the cRIO, battery, motor controllers, etc so I can start getting a feel for the space they will take up and how best to lay them out to keep the wiring tidy. I did a search for "Inventor dimensioning and layout" but didn't find what I was expecting. I have worked with 2D drawings when constructing switch boards - I'm wondering how you go about creating a 3D equivalent.
Matthew Kerr
Engineering Mentor
Team Melbourne
Victoria Australia
Unread 09-02-2013, 04:34
Allen B.'s Avatar
Allen B. Allen B. is offline
FRC #0973
Allen B. has a spectacular aura aboutAllen B. has a spectacular aura aboutAllen B. has a spectacular aura about
Although I have no experience with Inventor, what our team does in Solid Works is either mate to the planes of parts that have weird contours, or in most cases we make a mock part that has the same dimensions and weight properties but has flat sides that are easier to work with. With less detail, it is also easier to work in assemblies.
Unread 09-02-2013, 05:44
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
There's all kinds of little tricks or things you can do. Reference geometry like planes and axis that are bound to the electronics can be easily mated to your layout board. Or you could try to find some feature on the electronics component model that you can use. Like if there's a hole or a flat surface in the center of the model, you could use that for mating and just set the mate offset distance to be whatever you need.
Blocks that approximate the size of the object while being really, really simple are great too. Depending on how complicated your layout is going to get this might not work, but in all likelihood 2 rectangular blocks could replace a jaguar for modeling purposes.
You could also just leave the models unconstrained and drag them around and then lock them in place. It's not really a great way to do things, but for free form layouts I think its ok.
Unread 11-02-2013, 18:21
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
I agree with the suggestion of using work features such as planes, axis, or points as the best work flow for unusual shapes.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
