Go to Post Instead of arguing about what should have been, learn from the breaks, and celebrate the gracious professionalism being displayed by the other 99% of teams. Word. - PVCMike [more]
Unread 08-02-2013, 13:58
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question FRC Labview file permissions build error
Dear CD,
I am moving some files from my desktop to my laptop and when building on the new laptop I receive a file permissions error. I tried logging on as the administrator when beginning FRC Labview and that route did not work. What is the trick to making this work? Is part of the issue that Windows has multiple users on both my desktop and my laptop?
Thanks in advance for any help on this matter.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 08-02-2013, 14:02
Re: FRC Labview file permissions build error
I think running LabVIEW as an Administrator should solve your issue. Right-click on the LabVIEW shortcut, select Properties, click on the Compatibility tab then check the box to Run a Administrator.
Unread 08-02-2013, 14:39
If it's the error I think it is, the "file permissions" wording is a red herring. The true problem is probably that it's trying to build the .rtexe in a nonexistent folder.
Open the project and find the "FRC Robot Boot-up Deployment" build specification. Right-click it and choose "Properties" from the popup menu.
In the "Information" category, check the Local destination directory to make sure it matches the actual location of the project on the new computer. It's likely that the user name part reflects the location on the old computer where the project was created. Fix it and try building again.
Unread 08-02-2013, 15:14
marccenter's Avatar
Smile Re: FRC Labview file permissions build error
Alan,
THanks! That was the issue.
BTW, a "red-herring" is a misleading clue (non-native speaking Americans). In this case the error message is not helpful in pointing towards the potential solution.
Marc Center
Unread 02-05-2013, 23:02
xule xule is offline
xule is an unknown quantity at this point
Same problem, same solution. Thanks Alan.
