Go to Post I'm pretty sure most teams would be OK with being somewhere between Division by Zero and Cheesy Poofs! ;) - Dennis Jenks [more]
Unread 11-02-2013, 07:53
Al's Annual Inspection Thread 2013
Everyone,
I am starting this a little early this year to remind everyone of a few things during this final week of build.
1. The Inspection Checklist was released last week. Please use it to check over your robot prior to bagging next Tuesday.
2. There are significantly more motor choices this year, however, that list is not unlimited. There are specific quantities of each motor that can be used on your robot. The motor list is separate from the Inspection Checklist since it so long.
3. This year bumpers do not need to be bagged so don't worry how you are going to fit them in the bag. You can, of course, add them to your robot and include them in the bag. They will not count against your 30 lb allowance if you choose to keep them separate.
4. Don't forget you need to include belay points on your robot. There are no exceptions.
Enjoy your last week of build. I will add to this list after stop build. I hope the teams in the northeast have dug out of the heavy snow and everyone is safe and secure. Good luck all.
Unread 11-02-2013, 08:38
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Al's Annual Inspection Thread 2013
Thanks for doing this thread every year, Al. Inspection is an important part of the events, but it does not need to take a lot of time if teams prepare well. Less time with your robot inspector means more time for other kinds of fun, like practice for your drive team.
Thanks also for the special mention of motors. My favorite topic!
The list of legal motors for 2013 (see <R32>) is very long, but there are some old friends missing -- for example, the FP motors from previous seasons are not legal any more. It will speed up inspection if teams can either (1) install motors so their markings are visible to be checked against the legal motor list, or (2) when that is not feasible, mark the motor's part number nearby or have a list handy to show the inspector which motors are used.
Richard Wallace
since 2003
Unread 11-02-2013, 08:51
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Here is the link to the Inspection Checklist, it's also linked on the Competition Manual page on the FIRST web site
http://www.usfirst.org/sites/default...nChecklist.pdf
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 11-02-2013, 10:56
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
There a few things you can do before you get to Bag and Tag and have to deal with the inspectors
1) Remember ONE wire per Wago.
2) Sharp edges. Remove them. I don't like to see blood, especially my own
3) Make sure your 120 Amp breaker (that switch that turns your robot on/off) should be easily accessible. I ask the teams what would happen if your robot started smoking and nobody could reach the switch to turn your robot off? Weiney roast.
4) Review the wire color coding and size.
5) If you are using a camera, make sure it is isolated from the frame. To check, get a multimeter/ohmmeter and check for continuity from the frame to the PD battery post. It should read over 10k Ohms.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 11-02-2013, 11:29
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
All teams should be familiar with Bag and Tag now, but there are still teams every year that don't have their form easily available when they get to the venue - get a plastic sheet protector and tape it to your bag, then put the form in there!
My list of items every team should check now, while they still have time to fix them:
- Check that the FRAME PERIMETER is <= 112”
This does NOT include minor protrusions like bolt heads.
- Check the starting configuration
Everything on the robot must be within the vertical projection of the FRAME PERIMETER
This can be checked by pushing the robot against the wall
- Check that the weight of the robot is <= 120 lbs, and the weight of the bumpers is <= 20 lbs.
- Check that all motors are on the legal motor list
Make sure there are no Fisher Price motors, and compare all motors to Table 4-1.
- Perform a basic check of the electrical system
Use a multimeter to ensure the chassis is electrically isolated.
Check for appropriate wire gauge sizes
- Perform a basic check on any pneumatic systems
Ensure proper stored and working pressure
Check the system against the minimum system shown in R79
- Ensure the robot has appropriate belaying points (required for every team)
These can be eyelets with a ¾” opening or exposed structural members
If you doubt the robot can be supported by these points, have the team lift it
Be extremely strict about sharp edges near the belaying point
Suggest wrapping edges of the belaying point in duct tape, if frame is used
- Check that the battery is secure
Think about what would happen to the battery if the robot was upside down
2016: Lake Superior WFFA
Unread 11-02-2013, 14:17
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Any advice for a first time robot inspector? I would be particularly interested in any threads or documentation that has more examples on what is and is not legal for bumpers this year. i am not sure I know what is really acceptable for a corner climbing robot.
This is the zeroth day of the rest of your life.
Unread 11-02-2013, 14:33
dtengineering's Avatar
AKA: Jason Brett
Wow! Absolutely nothing in there about safety shields for high speed rotating equipment.
Given the number of shooters that will be running wheels at several times their design speed, I really expected something about "high speed rotating mechanisms are shielded to reduce the likelihood of injury during testing or in the case of failure of a rotating component".
I mean R08 covers the general concept:
ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
But I was hoping for something more specific, so that all teams would know, in advance, that exposed shooter wheels likely "cause an unsafe condition".
Jason
Unread 12-02-2013, 07:05
AKA: Warthog
What do you mean absolutely nothing about safety shields? ^ there it is
Remember that the Robot Inspectors are your friends and are there to help you. If we find something wrong, with your robot, don't take in personnal.
Unread 21-02-2013, 07:38
Well,
Now that everyone has bagged their robot using the official FRC bag and secure seal tag, you are good to go right? Not quite yet.
One of the biggest issues for inspectors every year with B&T is having teams produce the B&T forms. You should have filled this item out when you bagged the robot on Tuesday. Now is the time to make copies and insure that the original goes to someone who will be moving with the robot to competition. On a number of occasions, we have had teams with the form in the hands of a teacher who didn't travel with the team or the team captain who got the flu just before the competition. If you want to maximize your time on practice day, be sure to have the form handy when you arrive.
This year, the new rules will confuse some people. At this time, all robots must have two belay points on their chassis. It doesn't matter if you can't climb or intend to climb or even wish to climb, you must have them on the robot to pass inspection.
While there are a lot of motors on the allowed list this year, some past motors are no longer legal. Now is the time to check if your motors are on the allowed list and be prepared to change them at competition if they are not. Notably, the Globe motor and Fisher Price motors are no longer legal. The motors must be identifiable so no painting or other than allowed modifications are legal.
Bumpers...Every year this is a problem. We have gone to great lengths to simplify this. Bumpers must cover 8" of frame on either side of any exterior corner. Bumpers can be built after stop build, they do not count towards the 30lb allowance of parts to be carried in at competition.
First has tried to think of everything you might come up with in design and planned for that. However, you are really good and sometimes there are things that we didn't think of. The Q&A is your friend. If you thought of something, I bet someone else did too and already asked the question. If it was of some great importance, FRC also added it to a Team Update. Now is the time to check through both of these resources. Inspectors will have up to date lists of items that affect your robot construction. Each week they will be inspecting for these items. If needed, a revised inspection checklist (also available on the First website) will be issued.
That is all for this installment. Good Luck everyone.
Unread 21-02-2013, 08:40
Well,
The best way I've seen to avoid forgetting your form is to securely attach it to your bag! Get some duct tape and tape a sheet protector to the bag. Slide the form into the sheet protector and you'll never forget it.
Please note, that if you're transporting your robot to competition in the back of a truck or on an uncovered trailer, you'll want to keep wind in mind... You don't want the form blowing away while cruising down the highway 100 miles from competition!
Unread 21-02-2013, 12:33
AKA: Warthog
If you are transporting your robot this way, please cover it up.
Last year, at SMR, a team brought their bot in a truck bed. They also used aluminum duct work for the basketballs. The ducts shredded their bag and it took awhile for them to get inspected.
Also, I hope you didn't put your B&T sheet inside the bag with the robot
Unread 21-02-2013, 08:44
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
ditto to that! I'm also noticing a lot of this in videos (some labeled as reveal) with no wheel covers.
I'm having flashbacks to breakaway when we spent precious manhours making sure we didn't allow balls under our bot only to have FIRST decide that as long as a whole lot of people are doing it, then lets not follow the rules...
Unread 21-02-2013, 13:36
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Jason
Add me to the list for this one too. I think this could be a major safety issue. I've seen a few with wheels/discs spinning UN-captured or UN-encapsulated at very high RPM's that are probably beyond tolerances of the wheels/discs.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 21-02-2013, 13:57
OK,
I will bring this up but consider that rotating devices do come under the Safety Rule
R08
A greater concern is materials used for friction on the rotating device. Please be sure that you have chosen wisely when you assembled your spinner/wheel/tire. Some of the wheels used in the past are not meant for the high RPM you may be running on your shooter.
Unread 21-02-2013, 14:58
dchartley dchartley is offline
FRC #3684
dchartley will become famous soon enough
We built a curved 1/8" thick aluminum guard for our high speed pneumatic wheel so we wouldn't have problems during inspection because this had been mentioned in another thread.
Doug
