Go to Post FIRST is all about working with others. - briholton [more]
Unread 12-02-2013, 15:44
Jak2Rich Jak2Rich is offline
FRC #2495
Jak2Rich is an unknown quantity at this point
Please explain how to hook up a compressor like im a 5 year old
My team lost their pneumatics person and has no clue how to hook up a pneumatic system. Help us figure out how to power a compressor and operate a solenoid.
Unread 12-02-2013, 15:52
Re: Please explain how to hook up a compressor like im a 5 year old
Programming details depend on the language.
They all have special Compressor functions that do the work for you.
Wiring is pretty simple:
  • Compressor wires to a Spike, the Spike to the Power Distribution Panel. Use a 20a breaker and replace the 20a fuse in the Spike with a 20a breaker.
  • The Spike gets a PWM cable controlling it from a Digital Sidecar Relay output.
  • A Pressure Switch gets wired to the Signal & Ground pins of a DIO on the Digital Sidecar.
  • The solenoids are wired into the Solenoid Breakout on the cRIO Solenoid Module.
  • The Solenoid Breakout gets wired with either 24v or 12v power from the Power Distribution Panel, depending on the voltage of the solenoids you plan to use.
Tubing all the pneumatic components together is a little more involved.
See if this helps any: Pneumatics Step-By-Step
Unread 12-02-2013, 15:55
FRC #2495
Thank you. We can be idioits sometimes. This will be a big help. Thanks again.
