Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Unread 12-02-2013, 21:24
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Atonomous
How can an autonomous command in the command base robot be used?
Can it call other commands to run?
Any examples would be helpful.
Thanks
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 12-02-2013, 21:48
inkspell4's Avatar
The title is spelled wrong it should be autonomous!
Unread 12-02-2013, 23:28
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: Atonomous
You would create a class thats extends CommandGroup and start it in the initAutonomous method in the robot template class. Look it it up in the WPI cookbook.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 13-02-2013, 16:03
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Atonomous
Here is an example of creating a command group that can run during the autonomous period. It is important to note that once you have created the command, it can be used during teleop too. So for this year, if you have a command that can, say for example, shoot from the pyramid, then if the robot finds itself next to the pyramid during teleop and you have that command "wired" to a button, you can use it.
http://Wpilib.screenstepslive.com/s/3120/m/7952/l/97994
Brad
Brad Miller
Robotics Resource Center
Unread 13-02-2013, 21:19
inkspell4's Avatar
How could i add a wait statement into the code between the commands as they run?
Unread 13-02-2013, 21:48
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Atonomous
You can either add a WaitCommand:
addSequential(new WaitCommand(5));
or you can use a command that does nothing (we have a command called DoNothing which does nothing and returns false from isFinished()) along with addSequential's timeout parameter:
addSequential(new DoNothing(),5);
I code stuff.
