Code messing up
So today we were trying to test some code.
We deployed it to the cRIO from LabView on our computer with no issues. However we tried to control the robot was it had finished loading and we were getting a "No Robot Code" error. Any ideas? |
Re: Code messing up
Im having issues like this, i can deploy code once then i can't redeploy again and the code is not functioning correctly
Re: Code messing up
Have you been placing all of your hardware from the begin file in the finish file to close the references?
Re: Code messing up
Teleop: Tank Drive and a simple control for our shooter Finish: Closing opened items So we are deploying straight from robot main. We are direct connecting to the cRIO 8-Slot. Should we try going through the bridge? |
Re: Code messing up
Re: Code messing up
I'm running it from Robot Main and I'm opening everything. Should I trying making a real-time app? |
#7
Re: Code messing up
Are you referencing a second module of some sort without there being one? Such as Digital Module II? Have you tried reimaging it and formatting the controller? |
#8
Re: Code messing up
So we built a an application and it worked. Thanks for the input.
#9
Re: Code messing up
I have a feeling you're crashing the cRIO. Try to run the code straight from Robot Main and see if it gives you an error of some kind. |
