Air Cylinders
Is it Okay to order Air Cylinders On Amazon????
Re: Air Cylinders
As long as they meet all other requirements for pneumatic cylinders, then yes. If you're ordering them New (not Used) then it's a pretty safe bet they'll be COTS cylinders and thus legal.
Re: Air Cylinders
You may also wish to check Mcmaster.com for prices and delivery window. Its unlikely they are cheaper than amazon but they might be able to get it to you tomorrow if you absolutely need it.
Re: Air Cylinders
Also how do i control two Air Cylinders At the Same Time?????
Re: Air Cylinders
If they are the same size and used in the same mechanism, you can put a tee fitting in the output of the solenoid to make both actuate at the same time.
Re: Air Cylinders
Do i use a Single Or Double Solenoid??
#7
Re: Air Cylinders
It depends on the cylinder, but most cylinders have 2 air inputs, so a Double Solenoid would be appropriate.
#8
Re: Air Cylinders
The number of cylinder ports do not determine if a single/double solenoid is used. Both single and double solenoids perform the same actions and have the same number of available ports. They actually use identical bodies, but the double replaces the return spring with another energizing coil. Why we choose one over the other has to do with how their behavior differs. A single solenoid has a spring return to a home position. It is energized to move it to the opposite position and will automatically return to it's home position when the energy is taken away.
It stays in whatever position it was last ordered to.
