What is the pan range on the Axis Camera servo?
I want the camera to face forward until a button is pressed. I just need to know the range so I can find the center. The tilt (Servo Motor) is working perfectly. The constants I currently have entered for Servo Motor 2 are jibberish placeholders. Thank you!
Re: What is the pan range on the Axis Camera servo?
should it be 0-90, 90-180.
also for a screen shot simply hit print screen, open paint, and paste.
Why don't you use the same ranges you chose for Servo Motor since that one works great?
90-0, 0-90 The total shouldn't be more than 180 and the minimum no less than 0. Both servos have the same range. |
