| View Poll Results: What will your bot weight this year? | |||
| Antweight > 60 lbs |
2 | 1.87% |
| Lightweight 60 - 80 lbs |
4 | 3.74% |
| Middleweight 80-100 lbs |
26 | 24.30% |
| Cruiserweight 100-100 lbs |
33 | 30.84% |
| Heavyweight 110-120 lbs |
34 | 31.78% |
| Sumo that needs a diet < 120 |
8 | 7.48% |
| Voters: 107. You may not vote on this poll | |||
Weight Poll
How is everyone doing with the annual weight battle. Did the smaller footprint help you make weight easier or did it not make a difference?
We are currently a tick under 80lbs and will probably finish a tick over. This will be our lightest robot ever beating out our Breakaway robot by about 15 pounds. |
Re: Weight Poll
Can you really be between 100-100 lbs?
Re: Weight Poll
We're right there at the max, we have about 8 pounds to play with after all is said and done which is actually a lot to have. Probably use it to spruce up the bot a bit.
Re: Weight Poll
Middleweight for us.
And they said a robot made of steel would be heavy. ![]() |
Re: Weight Poll
We'd love to go lightweight but we'll be closer to 90lbs.
Re: Weight Poll
Haven't weighed it officially yet, but with everything but shooter (including motors) and electronics, we're at ~80 pounds. Probably going to go up to 100 with all electronics, motors, lighting, and any other stuff, but won't hold my breath. The rest of the weight we will have will be used for designing a climbing mechanism to attach on at week 1.
ERdit: Weight without electronics is 87 pounds. Last edited by Anupam Goli : 15-02-2013 at 21:20. |
#7
Re: Weight Poll
We are trying to find something cheap to use as 10-15 pounds of ballast so we aren't playing Lunacy on the carpet. Someone thought of a disconnected battery, but I nixed that one...
#8
Re: Weight Poll
We've got something like 40 lbs to play with (who knew a simple robot would be so light!), so some ballast is in order to move our CG to somewhere there isn't structure at 30". ![]() |
#9
Re: Weight Poll
We've found that the local sporting goods store sells barbells in very nicely marked sizes. Now you can prove while climbing the pyramid that your robot really lifts, bro.
#10
Re: Weight Poll
Assuming that cruiserweight is supposed to be 100-110lbs...that's about where we'll be weighing in.
#11
Re: Weight Poll
75 pounds before climber here.
#12
Re: Weight Poll
135 on a good day...
#13
well our team always seems to go big or go home were heavy weight 115 was our weigh in today. I'm just glad no Swiss chesseing needed this year.
#14
Re: Weight Poll
I think we've successfully built the smallest and lightest robot ever to play a match in FRC. As we packed it up for the Colorado scrimmage tomorrow we hung it from a fish scale. Without bumpers and battery it weighed a whopping 37 ilbs. It's designed to do just one thing-----CLIMB! The size goes hand in glove with the weight. It's frame perimeter is 78 inches (15 x 24). It has two motors, gearboxes and speed controllers and no they aren't connected to the wheels. If you're going to be at the Colorado scrimmage tomorrow come by and we'll show and tell.
