Help! Labview manipulator code doesn't function!
Hi guys,
My name is Jack and I am the programmer for team 867. I am writing code for our manipulator system. However, the only motor that functions when I run the code is "VexMotor". As far as I know, the all the USB ports and PMW ports are correct. Here is a list of what I want the code to do and what actually happens: Press button one: VexMotor runs backwards - this works Press button two: WindowMotor runs backwards - nothing happens Press button three: WindowMotor runs forwards - nothing happens Press button four: FasterMotor runs forwards - nothing happens Press button five: SlowerMotor runs forwards - nothing happens Press button six: Pneumatic system pushes - not connected at the time when I tested the code SlowerMotor and FasterMotor are both Jaguars WindowMotor and VexMotor are both Victors I have attached a picture of my code. Does anybody have an idea of why the program isn't functioning correctly? |
Re: Help! Labview manipulator code doesn't function!
You used a Refnum Set in Teleop
It should be a Refnum Get Example ![]() Last edited by Mark McLeod : 15-02-2013 at 20:32. |
Mark could you explain how the vex motor could then work? I had an issue like this once and didn't believe I had put in the set instead get just because one of the buttons had worked.
I just pointed that out because it's an obvious error. Use of the Set instead of the Get is causing extra work, because it keeps replacing the Refnum entry 50 times a second for Joystick 3. I don't know what grief that might be causing elsewhere, but I suppose it could be suffering from a propagation delay. At the least it's probably wiping out the Joystick cache.
For debugging you can run Test mode from the Driver Station to see if all the devices show up on the Dashboard Test tab, and from there you can test each of them by clicking on "value", then using the control that appears at the bottom of the Test tab. That'll bypass the Joystick to remove it from consideration (or point to it as the culprit). P.S. You can also watch the Joystick buttons being pressed, so you can be sure the Joystick is working normally. BTW, the button operating the solenoid should light a status LED on the Solenoid Breakout if it's working. You don't need the pneumatic system to see if that's responding properly. Last edited by Mark McLeod : 16-02-2013 at 01:47. |
It wouldn't be a long/short pulse issue. The actual PWM signal is generated by the FPGA. The Motor Sets are just passing their requests to the FPGA.
It might be more along the line of the new joystick entry starts getting populated in parallel with Teleop from the last command packet and it only gets as far as the axis and button 1 before Teleop has read past the data and is getting zeros for the rest of the unpopulated fields. But then again, until you test everything, it could also be a broken joystick. Last edited by Mark McLeod : 16-02-2013 at 01:55. |
#7
Hi, thanks for responding Mark.
I have fixed the set to get. However, my original problem still persists. I believe the joystick is working because when I was running the code in driverstation, the joystick button would light up whenever a button is pressed. However, there would still be no response. Can you give me more details about the new joystick reading and command bracket thing? |
