Go to Post Compact gearboxes are a wonderful thing. - Cothron Theiss [more]
Unread 16-02-2013, 21:49
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
Solenoid Breakout required?
The control system setup documentation says to install a solenoid breakout module in the cRio, but I can't see anything requiring that module in the manual.
If we are not using any solenoids is that module required?
If it is required, how is it powered when using a cRio II? The version 1 has 4 spaces available on the power plug, but the version 2 has only 2 spaces available. My understanding is only 1 wire may be plugged in to any 1 space on a connector.
Thanks for any assistance.
Unread 16-02-2013, 21:55
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Solenoid Breakout required?
My understanding is that it is not required.
Unread 16-02-2013, 21:58
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
There are only rules that require an analog sidecar (battery voltage) and a digital sidecar (status light). Nothing requires you to have a pneumatics sidecar.
All opinions are my own.
Unread 17-02-2013, 02:17
If you do install a Solenoid Breakout, you can either power it with 12 volts or 24 volts. Both come from the Power Distribution Board. 12 volts would be from a 20 Amp branch circuit; 24 volts would be from the "extra" two connections on the cRIO power supply connector.
