Go to Post This is about more than building a robot, we cannot only do the fun things. If you are fully involved than you will be prepared to do anything in life. - Andy Brockway [more]
Unread 17-02-2013, 13:55
Team 2085 Team 2085 is offline
FRC #2085
Team 2085 is an unknown quantity at this point
Victor 888 High Pitch Noise
We're using the new victor 888s, they're driving three cims, and each are hooked up to their own victor using a tri cable. We've tested continuity of the PWM cable, and concluded that the cables are fine (with some more tests such as voltage tests) But when we enable it, some of signal lights are flashing rapidly, and whenever we move at full blast, the correct indicator lights turn on.
Unread 17-02-2013, 14:08
Racer26 Racer26 is offline
Re: Victor 888 High Pitch Noise
Not sure what you mean by a "tri cable" (unless you're referring to the three conductor PWM cable that links the Victors to the Digital Sidecar.)
It is normal for robots using Victor 888's to emit a high-pitched sound when operating at low speed. What you're hearing is an artifact of the motor coils being energized at a frequency that is well within human hearing range.
Unread 17-02-2013, 16:04
The high-pitched noise is normal.
It's the result of the 1,000Hz switching frequency of the 888.
Unread 17-02-2013, 16:17
FRC #2085
Ok, so what about the indicator lights? Thank you.
Unread 17-02-2013, 16:58
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
I believe that is also normal.
Academic Student (Forever)
Unread 17-02-2013, 16:59
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
The LED flash patterns are explained in the Victor User Manual. What you're describing sounds like normal operation.
