Go to Post its kind of a bad idea to implement traction control when you have no traction in the first place. - Uberbots [more]
Unread 18-02-2013, 03:21
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Exclamation Victor 888 "y" cable issues
For our drive train motors we are running 4 CIMs off of 4 Victor 888s using "y" cables to run two in tandem. We keep experiencing a strange issue of one Victor functioning normally when only it is plugged in, but as soon as the second is plugged in the solid light goes dark and makes a high pitched screech. When like that the screeching Victor outputs -12 volts even with no control input. We've swapped them with 884s and they function as expected. Are our Victors bad (we tried 5 out of the 24 888s we have, so it seems very unusual) or are we doing things wrong? We are considering sending them back to Vex and opting for Talons. If you have any ideas please be sure to share. Thank you all in advance
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 18-02-2013, 04:04
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Victor 888 "y" cable issues
We have been running Y cables on 888s for the past 4 weeks with no issues. They are on our drive train controlling 4 of the 6 CIMs.
Unread 18-02-2013, 06:47
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Same here. Running Y cables on the drive train with no issues or screeching as you describe.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 18-02-2013, 08:50
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
We had something of the same issue. We took out the y cable and it did stop the issue. But we also fixed some shorts. Although from what I have read on chief delphi y splitter cables on victors is a no no.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 18-02-2013, 09:05
Mentor,QCR Planning
Please point out some examples.
Unread 18-02-2013, 12:48
I tested for shorts as I made the y cable myself. none were found and our victors returned to normal when running by themselves, just together on the y cable seems to make them malfunction. We did finally get 2 888s to work on a y cable together. So I'm thinking that we have a bunch of faulty 888s
Unread 18-02-2013, 12:57
Engineering Coach
Have you changed sidecars? I remember reading somewhere that victors due draw more current from the PWM cables than the Jaguars do. If for some reason your sidecar isn't buffering the PWM signals properly it could not be giving enough current.
Unread 18-02-2013, 13:15
It is a brand new sidecar from 2013. we will try a swap, but I don't think that's it.
Unread 18-02-2013, 14:21
I don't have a Jag here to test, but here's some input current vs input voltage test data I ran on Victor back in August last year.
Unread 18-02-2013, 22:26
Engineering Coach
Alright, so I maybe I spoke to soon. We finally wired the real robot this evening and guess what happened to our lift side Y cabled victors. High pitch noise, trying to move but not at full speed. We had to take it off the Y cable for our demonstration. Switched to the Y-cable we have on the practice robot and it still has the problem. Haven't had to much time to diagnose. One side is working fine with the Y cable to other is not.
Unread 18-02-2013, 22:48
Sounds exactly like what we had happen. Did you test the Victors by themselves later on? We set aside all the ones we thought we might have damaged so we can test them after stop build to see if they were faulty or if we were doing something wrong.
Unread 18-02-2013, 23:20
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
We noticed the same thing with 888s. My suspicion is the 888's may have significantly lower "deadband" than the 884s, making them much more susceptible to slight variations in PWM input. If the calibration is slightly different between the victors, one might be seeing "neutral" while the other sees "+1% power". It didn't seem to affect our performance much- full forward on the joysticks gave us the green LED, full reverse gave us the red LED, just the neutral position seems to be slightly off. Gently bumping the joysticks one way or the other would reverse which 888 didn't have the orange neutral LED, and on occasion when the joysticks came to rest, both would be orange.
We haven't tried calibrating them yet, but based on what we observed of the symptoms, it may solve the problem.
Unread 19-02-2013, 00:11
There's no "may" about it. They do.
