Balancing a Pneumatic wheel
We've got 2 6" Andymark pneumatic wheels on our shooter, and we were having some major issues with vibration due to the air spigot throwing off the weight distribution. We removed the innertubes entirely and filled them with bubble wrap which helped some, but it still vibrates badly because the tire doesn't seat particularly well without inflation. For teams that are using pneumatic shooter wheels, what did you do to balance them?
Also, did anyone find a different type of wheel to be superior? |
Re: Balancing a Pneumatic wheel
We are using a single 8" pneumatic wheel and the team taped a few small nuts/bolts into the spoke opposite of the filler tube. Works fine.
We were running the tire without an innertube but discovered it flattened out too much and it was difficult to get a good grip on the disk. |
We used 1/4 oz tire weights from Harbor Freight - they're adhesive backed and worked like a charm!
Two long bolts on the holes opposite of the air nozzle, with washers stacked on them. Our sweet spot was 9 washers on each bolt, give or take a few for others depending on bolts/nuts and such.
Am I the only one that watches lunch with Andy? |
Step 1: Take the inner-tube out.
Step 2: Fill the tire with pool noodle which has been cut in half. Step 3: Thank your friendly M'Aiken Magic mentor from South Carolina. Works like a champ, promise. |
Seriously, don't forget to take into account that these wheels are running at speeds they were NOT designed for. Make sure anything you attach to them can handle the speeds. |
#7
Do what we did: Just take the tubing out! Literally. Just the hub and the rubber tire. No inner tube. It works beautifully.
#8
When you couple the strong adhesive and with the centripetal force of the wheel, there's no way these puppies will fly off. |
#9
I know team 3130 removed the whole inner tube and replaced it with pool noodle and had great success with it.
#10
The wheels are well balanced (though there is still enough vibration to matter) and there is a shield in place to keep debris from flying out if something comes apart at speed. |
#12
Here's how I did it:
I also used stick on lead weights for RC airplane balancing, but I simply did not trust just double sided sticky tape to hold them inside the wheel. I stuck the weights on where they needed to go and then I used 30 minute epoxy as the final balancing "weight". This also helps to secure the weights in place. http://www3.towerhobbies.com/cgi-bin...&I=LXK204&P=ML The fourth picture is what happens after you spend time balancing the wheel and the tire decides to spin the tube inside the wheel resulting in an unbalanced wheel... Last edited by team222badbrad : 24-02-2013 at 17:31. |
#13
We found that the valve stem was being pushed outward by centrifugal force.
So we put a zip tie around the valve stem and the bolts holding everything together. Seems to work well. Has been reliable. We are only running about 3000 rpm. We are not trying for real long shots. |
#14
