Me and my team have been working ruthlessly over the past 2 weeks trying to make our shooter work the best we can. We are using a linear shooter with 2 andymark 8in rubber tread wheels on a mini cim each. We finally got it shooting decently(shooting from the back of the pyramid near the center of the field and only just making it into the 3pt goal) by putting surgical tubing around the wheels to make them like pneumatic wheels for grip and compression. This worked fairly well except that the tubing expands an awful lot and wears down to quicky. We have been experimenting with different ways of getting the same result as the surgical tubing that just doesnt wear as quicky but are at a loss, so we were wondering what you guys have been using on your wheels(if any)?
Re: Shooter wheel covering
We tried that today by using weather stripping however are results went from the 17 feet or so to 2 feet.
What does the wall look like opposite the shooter wheel? Are you using any form of grip tape? The KoP grip material works excellent.
A photo might help out here. |
-First off, are you saying you shot multiple (i.e. minimum 5) and they went approx the same spot 17ft away, then another minimum of 5 discs with the weather strip and they all landed at approx the same place 2ft away? -With the weatherstrip, did you play with the compression? Do you have the ability to move the wall opposite your wheel to have any compression you like? |
Yes that is how we tested
![]() This here is it at an earlier stage in development however all we did after this was reduce weight, the rear wheel no longer has surgical tubing on it as when they both expanded they rubbed against each other, 2 mini cims now, and we have a Lexan top to prevent ride up of Frisbees. Unfortunately I don't have any recent pics . We will have a look into the KOP grip material. Unfortunately it is march break for us and we don't have access to our shop so no further testing can be done for a week . We did play with the compression as well with our adjustable wall |
#7
My suggestions:
1) get rid of the surgical tubing just to remove that as a variable (for this test anyways) 2) try (insert compressible material here) on the wall 3) play with the compression through a full range of barely grabs the disc to "whoa, you sure you want to compress the disc that much"? -always shoot enough that you KNOW it is repeatably bad before moving on repeat 2 & 3 with different materials The disc slipping on the wheel AND the disc slipping on the wall are different variables and you will want to have an grasp on their effects to your shot. |
#8
Compression on the wall of the shooter, though, instead of the wheels may be totally different. The compression of the pneumatic wheels help grip the frisbee and throw it better. Either way, try adding more compression with both a solid material and something compressible on the wall and see what happens. |
#9
Nice bot in the video btw! |
#10
With our pneumatic wheel set up, we are actually bearing more on the side of the tire. The tire helps to keep the Frisbee down on the platter. The tire height is optimized for the wheel speed. It has been consistent and we are not seeing a lot of wear on the tire..
#13
I was at the gtr east today and noticed several teams using an adhesive rubber that was fairly hard but still compressibly with a slippery surface. Does anyone know where i might find something like this. Me and some of my team mates were talking today and think it would be a good siding for our adjustable wall. It should allow for some compression but low friction for the frisbe to slide along while being spun and accelerates by the wheels.
#14
This will not help with distance because the point of having a compressible material is to increase the time and amount of frisbee in contact with the wheel. If you don't make the wheel compressible, the frisbee will only touch at that one point where it and the wheel are tangent.
