Go to Post FIRST isn't about the money. It is about the experience. - dubious elise [more]
Unread 09-03-2013, 20:42
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
pneumatic system Wiring
How do we Wire our Pneumatic system?????
Pneumatic System Consist Of:
Two Double Solenoid, Festo series VUVG, 12 volt
Unread 09-03-2013, 21:11
xisybyl xisybyl is offline
FRC #3648
xisybyl is an unknown quantity at this point
Re: pneumatic system Wiring
Assuming you are using LabVIEW, look up the software examples (see Support - Find FRC Examples). You will see a wiring diagram on the Front Panel. You can also look at the overall wiring diagrams.
Unread 09-03-2013, 22:43
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Pneumatic tubing with "low" pressure air from the regulator goes into the "input" side of the solenoid. Tubing connects the output ports to the cylinder. (I don't believe it matters which output goes to which end of the cylinder, but don't quote me on that.)
Both of the solenoid "power" leads go to the solenoid breakout (which is wired for 12V). Cut one of the "2-Wire Jumper" cables from the KOP in half, and connect the leads to that. The +12 pin on the solenoid breakout is the further one from the circuit board.
