Go to Post "We just fundraised $5000 for registration, and you spent it all on balloons?" - [more]
Unread 10-03-2013, 23:10
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Victors?
I downloaded the Victor 888 .STEP model from VEXPro, and this is what it looked like.
Is that normal, and if so, can someone tell me why it is like that?
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 11-03-2013, 01:14
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: Victors?
What you are seeing is just a material. The .STEP file is rendering correctly, but Inventor has just assigned a default texture to the model. If you go up to the top ribbon, you will notice the drop down labeled "Generic". This drop down controls what material your part is made out of. Select the entire part, and then change that drop down to something else, probably a black plastic material.
You can also change individual components, by selecting each part separately and using the drop down to change the materials.
Unread 11-03-2013, 02:15
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Victors?
You may want to change the material as [zaphodp.jensen] points out, but the main issue here is that Inventor has imported the STEP file as a surface object instead of a solid object. Try using the Stitch tool (in the Surface palette of the 3D Model tab) to convert it back to a solid body.
FRC 766, 2015-, Mentor
Unread 12-03-2013, 13:21
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Victors?
I am sure I created that as an Inventor assembly. When I get back to my own computer I will check for you.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 12-03-2013, 15:03
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: Victors?
When laying out our electronics board, we used the victor 884 model provided from the autodesk education website instead. Also, the autodesk education KOP has the older spike design and the CAD model is smaller than the actual thing.
