Go to Post Why dress to impress when you can speak to impress? - Joe Matt [more]
Unread 14-03-2013, 00:13
andres20perez andres20perez is offline
FRC #0545
andres20perez is an unknown quantity at this point
Problems with UDP 1140
We are having trouble communicating from the robot to the dashboard, using any of the UDP ports and the TCP ports.
Any suggestions?
Unread 15-03-2013, 23:32
Re: Problems with UDP 1140
My standard suggestion for any problem like this: give some details. Tell us what you're trying to do, how you're doing it, what you expect to happen, and what happens instead.
Since this is probably a software issue, it would help for you to show us your code, on both the sending and receiving sides.
