Understanding FiM State Qualification
I was looking at the FiM results and rankings spreadsheet (found at firstinmichgian.org), and had a question. Some teams are shaded green, to show that they have already qualified for States. I was just curious how that information would be available at this point, as the Michigan Rules Supplement only states that the top ranked teams teams qualify (as do the winners of the state specific awards). Obviously some teams like 2474 are far enough ahead of the pack that it's obvious, but for the lower ones in that category, is it just a certain point threshold that must be passed?
Appreciate any clarification |
Re: Understanding FiM State Qualification
Good Evening Mr. Pockets,
The teams that are already highlighted green have either won a district or won an award. The former is the 3 teams who win finals. While the latter is the Chairman's Award Winners. Hope that clears everything up for you, Brian Ha |
That confuses me though, as my former team (1189), is currently highlighted despite only making it to semifinals at highest, and only winning two spirit awards.
64 teams will qualify for MSC. That number includes the District Chairman's Award winners from each event, and the balance consists of the teams with highest FiM ranking point totals. In the past, it has taken about 50 points or so to make the cut. That number will vary with the number of teams in MI, etc. It appears that FiM has identified some numbers (around 65 for teams with one event so far and 75 for teams with two events) that they consider to be a safe bet for qualifying, and they are just letting these teams know so they can plan ahead. Perhaps FiM has calculated numbers that are a mathematic lock. I don't know. I am sure that it isn't about winning awards or events. We are "green", but we tried to register with FIRST and they wouldn't let us yet.
I believe Wayne is correct on this one. What they probably did was if they gave the "max score" to every other team, would you still qualify, i'm assuming that if this happened you would still qualify. It is a simplistic mathematical calculation.
So i going to give a shout-out to the person/people who do and thank them for this in advance. |
Wait... Hold on i looked more carefully at the file and 910 isn't qualified, now if you all remember they ended up winning with 70 and 862 at Kettering. Unfortunately i think what might be going on is they might be having some issues with the green highlighting. I wouldn't trust it at this time unless you have won a district.
#8
Also with what magichau said, yea i agree basically. The ones who have 70+ and only one district played are usually the district winners as well. Or usually around there. I still believe there are some mistakes but they are doing a pretty good job and i say hold on to week 6 before being positive your going to actually make it. |
#11
Winning a event does not grant you a spot at MSC. Also you can kind of figure out the cut off number points wise on your own. If you figure out the total points given out at one event and multiply it by 11 and divide it by the number of teams competing (times 2 for two events) you come up with a number of about 25 points per event, or 50 for the year. I think if you set that 50 as your mean on a normal distrubition, you can come up with a number close to the projected cut off. Which a few of us have found is to be around 60 points.
#12
This is not a correct statement. The only automatic way to qualify for the Michigan State Championship event is to win the District Chairman's Award. Winning an event earns you a significant amount of points. If you perform well at your second district, you will most likely be qualified, but it is not a direct guarantee that you will move on to the MSC.
#13
Case in point: There were three teams that were a 2nd pick for a winning alliance at a district last year (2012) that did not qualify for states.
#14
At this point, the rankings don't really matter because not every team has played two events, while it's great to see how your doing against other teams I think probably to stalk the rankings after the Bedford district, nothing is set in stone yet. Some people [at least on my team] argue you'll need 50 points and others say high 70s. We don't really know.
#15
I would say if you have 70+ points you are 100% in for State.
