Talon vs. Talon SR
Can someone explain (to a simple programmer) the difference between the Talon and Talon SR?
What is the practical difference between "Locked Antiphase Rectification" and Synchronous Sign Magnitude Rectification"? Was the change made to address any specific problem or application? TIA |
Re: Talon vs. Talon SR
Generally speaking, you shouldn't see any impact from the change. From what I understand, it is supposed to give the same motor performance (in other words, you can swap one for the other and not notice a difference in how the robot drives), but provides lower temperatures in the Talon itself when the motor is stalled. This means the Talon will be less likely to burn out when used.
See also Pages 17 & 18 of this PDF from Siemens:
ftp://ftp.dei.polimi.it/outgoing/Mas...r%20drives.pdf |
Still absorbing the material, and I will likely have additional questions, but thank you for the links.
According to Mike Copioli (from CTRE) it means that the Talon SR will run cooler when stalling the motor. Aside from that, basically no practical difference. Technically speaking, Talon and Talon SR would behave differently when outside forces (like gravity, on a slanted surface) are contributing to the drive force. Mike says the difference in practice is negligible to non-existent.
#7
Check out the latest user manual (text in orange) ...
http://crosstheroadelectronics.com/T...Manual_1_3.pdf ...or andymark... http://www.andymark.com/Talon-p/am-2505.htm ...for the details but basically Talon SRs are more efficient at stall (less heat), expanding the no-fan usecase. Also the led blink pattern is more distinct between Full throttle (full forward/reverse - led solid) and "Less then full" throttle (99.999% in either direction - led blink). Led blink rate still indicates magnitude though (just like before). |
