Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 09-04-2013, 19:18
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Optical Flow
Hello. I am attempting to use NIs optical flow (HS) VI. Unfortunately, I get an error: "IMAQ Vision: Incompatible image size."
The code is using IMAQdx for image acquisition. I have found out that this is not the issue though, as other VIs, such as colorThreshold, work perfectly fine.
The vi is attached.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
Unread 26-05-2015, 17:19
prattster1995 prattster1995 is offline
Rookie
AKA: Joshua
FRC #3407 (Meustangs)
prattster1995 is an unknown quantity at this point
Re: Optical Flow
When I started working with this VI I received the same error. The solution I found is the fact that both your current and previous image must have the same dimensions for both the x and y directions.
