Using Processing for custom dashboard
Hello! I'm asking this question on behalf of a few of my colleagues whose area of expertise is in the language Processing. They're fantastic programmers, and can make any GUI you can imagine. I believe it's a highly object-oriented dialect of Java (I don't program with it myself, so I'm not sure), and apparently there are libraries you can import to compile it as regular Java. Our actual robot is programmed in C++, and we've never used network tables before. Is it possible to construct a dashboard that can send data to and from the robot using Processing? Thanks!
Re: Using Processing for custom dashboard
Why not just use Smartdashboard?
If you want to use Java, just extract the NetworkTables bindings from SmartDashboard. They have a separate jar file available that has them. The JAR is also distributed with the C++ stuff, look in C:\WindRiver\WPILib\desktop-lib
We did our custom dashboard in python, also using NetworkTables. As long as both sides are using a common communication mechanism (like NetworkTables), it doesn't matter what language either side is written in. |
Yup.
Can you inform me of somewhere I could go to learn? Thanks, by the way
#7
This document covers getting the client (ie dashboard) side of network tables running in netbeans. http://wpilib.screenstepslive.com/s/...client-pc-side
#8
Network tables seem fairly straightforward from the example on that page. I was wondering if there is much lag/delay between sending and receiving information. We would like to send information from the keyboard to a Motor controller, which I believe has to be updated once every 10ms or so... so that's a lot of information. Do we need to add delay (such as a wait statement or state machine) to both sides of the code or should it be okay to just attempt to send data back and forth in real-time? Also, should we create separate network tables for input and output communication? Thanks!
#9
We use raw Java on the display and custom network code to get custom packets from the cRIO. The data structure is 200 bytes, and contains every input, sensor, motor output, pneumatic state, and vision targeting parameter we have. Then we use Java reflection to open up the data structure and print it on the screen in a panel for quick debugging -- reflection avoids the need to update the data printer every time the software kids need the data structure change to change. We found that using custom packets is less processing and bandwidth-intensive than the Network Tables since we can control the data rate directly. The display also stores the data to file in a .CSV format for quick telemetry analysis post-match. Avoiding Network Tables also avoids "heavy weight" library dependencies, which has bitten us in the past when we've swapped laptops around.
The kids wrote some code around the data structure for a GUI. We may do touch-screen next year, but not at the expense of our current goals (plus a physical button board is better for the offseason stuff we do). Our software goals for the display are more along the lines of quick integration debugging, sensor tuning, & match replay rather than live match control. Our drivers rarely take their eyes off the field. I've never heard of "Processing" until now. Will have to look that one up. Last edited by JesseK : 18-04-2013 at 14:43. |
#11
Thanks everyone! Hypothetically, we now have all the knowledge to make a custom GUI than except the camera display (just the display, not vision processing. Eventually, we'll do that on-board). I believe there's a lot of stuff in WPI for that. Would we have to set up an entire robot project (configured and everything as if we were actually controlling the robot with it) to utilize that or just import it like we did with NetworkTables?
#12
If you do this please document it. I really like the processing language.
