Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 17-04-2013, 18:04
Priyesh69 Priyesh69 is offline
FRC #3988
Priyesh69 is an unknown quantity at this point
Question about shifting gearbox?
Hi, we are thinking about buying a shifting gearbox (ball shifter or super shifter) since we saw how effective they are but first i want to know how they work(the shifting). Is it related to programming and if yes how to we do it. Or it's only mechanical and do we need some extra gear or pieces.
Unread 17-04-2013, 18:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Question about shifting gearbox?
It's a mechanical gearbox, that is shifted via the control system, usually either using pneumatics, or a servo.
It is therefore programmed like you would program either a pneumatic actuator, or a servo.
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Gear shifting is done with either pneumatics or servos. If you have a pneumatic system on your robot, plumbing in two small cylinders will not be difficult. I have found pneumatic shifters to be quicker and more reliable than servo powered ones.
To add shifting you will have to replace your gearbox and potentially much of your drive-train of you are modifying an existing robot. Adjusting and readjusting chains or belts with idlers is no simple task, especially if you haven't designed the robot in CAD.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 17-04-2013, 19:26
FRC #3988
Thank you for helping shed light on the issue. Do you have any recommendation for a gearbox that can shift with pneumatic. It's for our list to buy things for next year so we won't be changing the robot.
Unread 17-04-2013, 19:29
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
If you do a search here on Chief Delphi you'll find a lot of the answers you are looking for.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-04-2013, 19:39
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
The gearbox is mechanical but is shifted pneumatically via programming. We have used it this year. I highly recommend that you use 2 cims per gearbox for the speed and torque. 2 cims is okay but will draw a lot of current. Our gear ratio that we had was High speed was 24:1 and low speed was 6:1. It was easy to program them in java for my team. I also do encourage you to have a button that kills robot driving when you are shifting then drive or else you are throwing a piece of metal into spinning gears with a lot of power. It is not needed but recommended because of it leading to possible shifting problems in the future of its usage.
Unread 17-04-2013, 19:42
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Figure out your desired speeds/how exactly you wanna design your drivetrain(ie. direct drive or do a reduction with belts or sprockets) and from there, determine whether the VEXPro BallShifter, WCP Shifter, or Super Shifter would be better suited for you. Also of note, the Super Shifter can shift with a servo if you don't plan on using pneumatics next year.
Also, AndyMark are releasing a new shifter soon, so who knows what that will bring to the table.
Unread 17-04-2013, 19:47
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
If you do go with the pneumatic shifter you are going to want to use chains. It will come handy when you are going against a robot that is pushing you. These shifters worked amazing for us during our events in MAR.
Unread 17-04-2013, 19:49
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Why?
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 17-04-2013, 19:58
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
During our MAR competition at Hatsboro Horsham we had the belt drive and we had amazing torque. We started pushing 2 robots and when the third came there was so much power from the 3 robots that our belts started skipping or something along those lines. At night we had about an hour before pits closed and we switched to chains. Did amazing and pushed better than ever.
Unread 18-04-2013, 09:21
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Use a double solenoid to shift gears. Program it like you would a normal pneumatic, except that you'll probably want some sort of toggle between the different gears.
Unread 18-04-2013, 15:29
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
We used a double solenoid for ours but we didn't use a toggle because we did more high gear for the speed instead of low for the torque.
Unread 18-04-2013, 17:53
FRC #3988
We plan to use pneumatic next year also. Thank you for the help.
Unread 17-04-2013, 19:44
Xavbro's Avatar
Xavbro Xavbro is offline
AKA: Xavier Eldridge
FRC #5829 (Awtybots)
Rookie Year: 2016
Xavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to behold
The Ball Shifter from VEXPro is pretty good from what I've experienced.
http://www.vexrobotics.com/vexpro/ge...l-shifter.html
TigerBytes (FRC 4209): 2012-2013: Mentor
DiscoBots (FRC 2587): 2009: Member || 2010-2015: Mentor
Impact (FRC 2585): 2016-Present: Mentor
Awtybots (FRC 5829): 2015-Present: Mentor
Ri3D Team oRyon: 2014-Present: Programmer/Strategist
Unread 18-04-2013, 23:00
who716's Avatar
who716 who716 is online now
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
I 100% agree with you, we have been using pneumatic shifters every time we decide to have a two speed gearbox and never have any trouble with them at all.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
