Go to Post So, we should have respect for each other regardless of whether we are building our robot with a Waterjet or a Hacksaw. Construction methods will vary widely, but honoring your competitors should be universal. - OZ_341 [more]
Unread 27-04-2013, 06:52
RoeeVulcan's Avatar
RoeeVulcan RoeeVulcan is offline
With burning passion ;)
AKA: Captain Mortenfeld for you
FRC #3835 (Vulcan)
RoeeVulcan is just really niceRoeeVulcan is just really niceRoeeVulcan is just really niceRoeeVulcan is just really nice
How to make your robot withstand the beating
This year me and my team build a pretty strong robot, but it kept getting problems with a few mechanisms that were not built to be so strong, one little match were we had a comunication problem almost disabled our robot for the entire day (take into account it was the first match of the day).
So I was wondering, what do you pro teams do to build stronger robots, that can stand the thrill of the fight?
That's Captain RoeeVulcan for you.
israeli 2013 finalist
Unread 27-04-2013, 07:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How to make your robot withstand the beating
Build several that break. Each one will teach you many things not to do. It's called experience.
If you have the opportunity to spend some time looking at some of the really good robots up close you can learn a lot. Ask questions about why parts are the way they are.
Unread 27-04-2013, 08:25
RoeeVulcan's Avatar
FRC #3835 (Vulcan)
I opened this thread in an attempt to learn from other teams experience, guessing they had a lot to teach me. I would love to know what your team did this year to a assure themselves on a robot that would come out of the field the same way it got in
Unread 27-04-2013, 09:23
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Ok, I'll give you a few tips. Depending on the game and your robot design, they may or may not apply though.
1> The KoP frame is very strong in the x and y directions but is flexible in the z (specifically twisting in pitch and roll). This could allow the frame to permanently deform with the 'vigorous interaction' with other robots (or this year ... falling). We usually box our frame. That strengthens it (and makes it heavier) and gives us a second deck to attach devices.
2> If you don't have to cantilever your drive system, don't. If you do, then calculate the twisting forces (especially side loads) and make sure your gearbox mounts can handle that.
3> If you use the c-channel, wherever you attach something put a wood block (or other support) into the c-channel. I've seen too many crushed and twisted c-channel frames in my day
The last one is just a guideline: When building something to survive impacts it must either be strong enough to withstand it or flexible enough to not care.
___________________
- Tennyson, Ulysses
Unread 27-04-2013, 10:15
pfreivald's Avatar
AKA: Patrick Freivald
Solder is better than quick disconnects.
Electronics should be well-protected from 'vigorous interaction'.
Don't skimp on material where you need it (this is largely an experience thing).
Drive it like you stole it, before you bag it!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 27-04-2013, 12:24
Andrew Lawrence
Posts: n/a
Make it out of steel.
/thread
Unread 28-04-2013, 09:05
MrForbes's Avatar
AKA: Jim
i understand what you want to do....you want to learn from the experiences of other teams. I think that is great, and this forum is the best place to do that.
But I also know that the best teacher is experience. I know a lot, most of it is learned from making my own mistakes, some of it from watching the mistakes that others have made. I still have so much more to learn, and I know that the only way I can learn it is to try, and keep learning as I make more mistakes, and have a few successes along the way.
At Championships this year we had a sort of major structural failure of our robot. I had anticipated this failure, and had thought of making a brace to prevent it, but never got around to it because the robot was working OK and we had plenty of other things to worry about. The competition here was really tough, and our drive team had to drive the robot really hard just to try to keep up. I also discussed this with several of our students, and they seem to have a good understanding of how important it is to try things, and see what works and what doesn't, and make sure to learn from the failures. Failure is the best teacher.
The trick is to figure out how to learn from from others' failures, or better yet, how to experience failures of your own in a way that do not really hurt, but teach you well. Many of the top teams spend many hours trying different ways to do things, and they test over and over until something breaks or jams or doesn't work right, then they change the design and test some more. It's called 'iterative design'. Having the will to keep working on something over and over is what seems to separate the best from the rest.
Another thing you can do is to post pictures of your design here on Chief Delphi, and ask for constructive criticism. I know that there are many very experienced people here who can probably spot potential problems quickly, if you provide enough detail for them to see what you are planning to build.
Unread 27-04-2013, 09:03
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Some simple things that we have always done:
If you have a spare functioning robot with bumpers put bumpers on your robot before bag day and just have it sit there and get slammed a few times by your old bot. This will simulate rough collisions, and match play and also allow to see if your robot is top heavy and prone to tipping. If you lack a spare robot another option would be slamming it into something sturdy solid and unimportant.
Anything that exits the frame perimeter must meet one of these two criteria:
Is solid enough to withstand a robot hitting it, and can be quickly fixed if bent or broke.
Be flimsy enough to move out of the way of another robot.
For electronics your best bet is slow and steady. Once you know what you are building and how it will look give your electronics team the dimensions for their board and let them start building it so as you get done with your robot sections they can begin laying out wiring exiting the board. This serves two purposes, it gives the students who like electronics something to do during the whole six weeks and not just the last two, and by giving them time they won't rush which will allow for connections to be solid avoiding com issues, watchdogs and other not so fun stuff
My final suggestion is make sure your drive team knows what the robot can and can not survive. Our current robot is small so we could use thick aluminum this year for our structure and everything above it was made from thick sturdy PVC board that has now gone through two regionals and championship without a bend or crack with heavy defense being played on us when ever we go out. However last year we were long and tall so when ever (rarely) someone would play defense on us we had to avoid and evade so to avoid unnecessary damage.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 27-04-2013, 13:25
Golto's Avatar
Golto Golto is offline
AKA: Pat Plude
FRC #4572 (BArlow RobAutics)
Golto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of light
Consider your center of gravity. A lot of damage comes from tipping (or falling). The bumper rules are in place to help alleviate the hit damage, worry about not damaging yourself and you'll build a fairly sturdy machine.
Unread 27-04-2013, 16:40
DonRotolo's Avatar
Back to humble
FRC #0832
Being in MAR, we go through up to 18 matches in each of three events (=48 matches) plus CMP and maybe a regional too... we need to hold together for maybe 80 matches! So building durable is required.
If you can, build a practice robot. It does not need to be perfect, just about the same as the production robot. We often use a previous year robot. Then all the prototype mechanisms get mounted.
Then beat the snot out of it. Slam it into walls, hard reverses and turns...try to break it. When it does, fix it stronger. Repeat until you are almost out of time.
Then build the final robot. Remember, it does not take as much time to fabricate the robot as it does to design it, so for the production robot we KNOW what needs to be built, it does not take long to build it.
As you can guess, it does not break often.
Unread 27-04-2013, 17:05
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
The most common thing to fail is the drive base. We try to complete it by week 2 or 3 and spend any free time slamming it into walls. Err... I mean programming autonomous.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 27-04-2013, 23:14
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
That depends... We had exactly 0 issues with our drive train this season (first time that's ever happened). We used the AM kit frame.
A good way to minimize the possibility of breaking things is to minimize the number of things that can break. In general, simpler designs will need fewer parts and end up being a little lighter, so you can use that saved weight to build with beefier materials.
Unread 28-04-2013, 01:30
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
"How to make your robot withstand the beating"
3/8" polycarbonate... just sayin...
http://goo.gl/8UNqE
Unread 28-04-2013, 02:01
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Our chassis survived the year pretty much unscathed. We machined ours out of tube aluminum stock (which can be found on McMaster & local aluminum retailers). This provided rigidity, along with a place to safely put 2 Clippard Air Tanks & our drive train modules.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 28-04-2013, 03:56
BrianArneson BrianArneson is offline
BrianArneson is an unknown quantity at this point
Build and experiment with different types of chassis and drive types (omni drive, swerve drive, tank drive, 6 wheeled etc...) and work out the problems that arise then when you got the time to fix them rather then during the build season. That way when you go to build the real one for that seasons robot you know how to assemble it. Usually it's pretty similar each year so you get good at it after a while. Summer is also a good time to use CAD programs to stress analyze where there are weaknesses so you can strengthen it up. Also, think triangles they are strong. Knowing when to use which type of nut and not leaving them laying around on the robot, it'll save you the panic later when one falls out and you don't know where it went. Cover Victors and Jaguars when working on robot, or use Talons, they can be a pain when they stop working and you have to take crucial time troubleshooting. Build simple east to fix mechanisms. This year not one thing broke on our robot because it was a simple dumper with 2 sides to hang, but still effective.
7 year FRC participant
Mentor on FIRST Team 662 - 2 years
Former student FIRST Team 4550 - 1 year
Former student FIRST Team 443 - 4 years
