Go to Post Geekier than me? That's a goal you can shoot for. You might make it, too -- in twenty years or so. :cool: - Richard Wallace [more]
Unread 29-04-2013, 23:42
drkabob drkabob is offline
Alum & Swag Coordinator Emeritus
AKA: Nathan Hakkakzadeh
FRC #1836 (Team 1836: The Milkenknights)
drkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant future
Introducing SwagDrive. The drive code of the future.
So I attended the World Championships this year. It was great seeing all these high level robots. However, I had a problem with them, they drove too straight. They drove with too much precision. There was no sense of "YOLO", the robots did not drive with enough swag.
So I decided to remedy this issue at the programming level, by creating SwagDrive. SwagDrive increases the robot's level of swag by at least ten-fold. By using new and innovative algorithms (or rather "swagorithms"), SwagDrive decreases the robot's consistency and accuracy so that when it drives on the playing field it looks a lot cooler.
It is similar to ArcadeDrive with some important modifications. If the change on an axis is not larger than the "swag barrier", it will multiplied by the "swag multiplier" in order to "swag up" the driver's inputs. If the input is larger then the "swag barrier" for that particular cycle, then the robot's "swag level" increases by one. If the "swag level" becomes over 9000 the robot enters a moment of ultimate swag and rotates for one "swag period" (truly a YOLO move). Many of these values still need to be tuned and modified to achieve optimal swag.
You can find an example implementation written in Java by clicking here. While I have yet to test SwagDrive on a real robot, I can assure you that it will swag up your robot.
I look forward to your comments and hope that we can improve SwagDrive for future competitions.
(If you haven't figured it out yet, this is a joke. You can find 1836's robot code here by our main coder. I would strongly recommend not using the SwagDrive code on your robot, as you will likely lose control and possibly hurt the robot and the people around it.)
Best Regards,
Nathan Hakkakzadeh
Website: http://nathancod.es/
Twitter: @drkabob
Reddit: /u/drkabob
Check out our team's website! http://themilkenknights.com/
Unread 29-04-2013, 23:44
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Introducing SwagDrive. The drive code of the future.
This is truly innovative. Can't wait to run it at IRI.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 29-04-2013, 23:46
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Pics/vids or shenanigans.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 29-04-2013, 23:55
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Sounds like the perfect drive for Tem 254: Teh Chesy Pofs.
Unread 30-04-2013, 00:04
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
I don't know if we would tell the difference; our driver drives like that anyway.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 30-04-2013, 00:26
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? Otherwise, looks like it's pretty easy to turn my swag on even as a rookie.
I should totally try this out. I don't know much about code, but oh well , you only live once.
Unread 30-04-2013, 00:32
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
I guess it won't be much of a change compared to us veering right when sending an only forward signal...
This would have been perfect for Team Harlem Shake videos.
We will be testing this tomorrow.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 30-04-2013, 01:57
Jackladd Jackladd is offline
Smooth Talker/Recon & Strategy Lead
FRC #1388 (AGHS Eagle Robotics)
Team Role: Tactician
Jackladd is an unknown quantity at this point
Can someone please actually do this?
Unread 30-04-2013, 06:35
Michael Hill's Avatar
Just multiply the inputs by -1 and it's drive CORRECTING code.
Unread 30-04-2013, 06:59
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Talking Re: Introducing SwagDrive. The drive code of the future.
We already have a program that does this, because we have mecanum wheels and a gyro, we spin in circles down the field. We haven't actually used this in a match (except for a mishap with our autonomous in a practice match (http://www.theroboshow.net/ ep.1 about 10:00)), but at public events it is great.
Unread 30-04-2013, 07:10
2789_B_Garcia's Avatar
2789_B_Garcia 2789_B_Garcia is offline
AKA: Bobby Garcia, AKA: #Catalyst
FRC #2789 (TEXplosion)
2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future
I've been working on a holla-nomic drive train where the wheels are angled to give alliance partners rep, props and street cred, but I've run into some electrical feedback problems with the wheels giving the props only to the chassis that they are mounted to...I've been calling this phenomenon "hollaback" lol
I saw someone's signature on here say: "A good driver always beats a good robot," and I thought that was rather clever, so I'm using it as my signature.
2014 Texas Robot Roundup Winners (with 624, 118 & Pearland Robotics Pre-Rookie Team)
2014 Texas Robotics Invitational Finalists (with 148, 3735 & 3999)
2014 Dallas Regional Quarterfinalists (with 2587 & 5057)
2014 Alamo Regional Finalists (With 2468 & 148)
Unread 30-04-2013, 07:20
One of the CSA's told a story at dinner about a team with a robot that would inexplicably stutter. They search the code looking for parallel updates to motors, bad math, etc.
They ultimately stumbled across a parallel VI stuck in the corner named "Harlem Shake". Not sure who the joke was on, but its one they will remember for awhile.
Greg McKaskle
Unread 30-04-2013, 14:46
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
highest # of posts to rep ratio I've ever seen. well done sir.
Unread 30-04-2013, 15:12
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
This is almost as cool as a triple-Killough nona-drive.
GitHub
Unread 30-04-2013, 16:02
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Sorry, I don't think anyone will ever come close to this.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
