Go to Post If you have to build the best robot to be inspired then we end up with one winning inspired team, and 999 losers. That is not the spirit of FIRST. - KenWittlief [more]
Unread 22-05-2013, 10:53
yajzse yajzse is offline
yajzse is an unknown quantity at this point
Simulation of Pneumatics in Autodesk Inventor 2013
Good day!
We have a project here that uses a flexible pneumatic actuator in which we need to simulate in autodesk inventor v2013.
Is there anyway that we can do this? Is it possible to simulate an air pressure entering a cylinder and control it? Thank you very much..
Unread 22-05-2013, 13:55
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
Re: Simulation of Pneumatics in Autodesk Inventor 2013
Sure, using Autodesk CFD, I have done something similar while simulating spud guns however, it will take some work as CFD has a very steep learning curve
Unread 22-05-2013, 14:25
Autodesk CFD? is it something like the Autocad 3D?
honestly, I am a noob with regards to autodesk inventor..
what I did was I have created a 3d model of a flexible pneumatic in autocad then imported it to autodesk inventor.. What I was thinking is that I can simulate it directly in Autodesk Inventor but I do not know how. I have thought of creating an air compressor also in autocad then import it again to autodesk inventor but I don't know how will I gonna input the air pressure that I want.
Unread 22-05-2013, 14:47
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
It's in a different family of products: Simulation Software. CFD stands for computational fluid dynamics. Steep learning curve is an understatement.
Unless your model is a lot more complicated than the overview you gave, I'd recommend just doing the math and the using the result to set the motion in Inventor. (Look at Integrated Motion Simulation at the bottom).
If you'd like more guidance, it's be helpful to know what you mean by "flexible pneumatic". Are you taking about moving a piston within a cylinder? Or this this a pneumatic muscle? (Or is this something like putting air in a hose and determining the forces on it?)
Unread 22-05-2013, 15:06
the flexible pneumatic that I was saying is a flexible bending joint..
the bending of the flexible pneumatic will depend on the air pressure that will enter its air cavity.
Unread 22-05-2013, 15:23
Siri's Avatar
Dare greatly
Ah - I've never done anything with flexible pneumatic bending joints, but I'd venture if you're looking to simulate something like a dexterous robotics hand, you'll want CFD. You could probably fake it to an extent with a combination of exogenous calculations and Inventor motion simulation, but CFD would be the real deal. Someone else here may know a more elegant Inventor workaround, though. I also bet there's a CFD forum out there, and even if you said you didn't want to use CFD, people on it would probably know Inventor approaches pretty well. Best of luck
Unread 22-05-2013, 23:42
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
What are you trying to learn from this? Why do you need to simulate air entering the pneumatic?
If you want to simulate the pneumatic at a certain position you can make a flexible pneumatic assembly, you can set up a dynamic simulation, or you can use positional representations. All of these are a million times easier than simulating air entering the pneumatic.
