Center to Center with belts
Our team is prototyping a drivetrain in the offseason and we wanted to try out building it with exact center to center spaced wheels with timing belts
Last year we used bearing blocks and tensioned them but it would be a lot simpler if we could do away with the tensioning I have a few questions about this Once we calculate the correct distance and build it, how do you get the belts onto the pulleys. Our previous experience shows that the belts have to be pretty tight so it seems that it would be very hard to put the belts over the flanges on the pulleys Also, how precise does it have to be built? All of our sheet metal work is done using a hand operated sheet metal punch and sometimes holes can be off by as much as 1/32 of an inch (less than 1/16) Would it be better to always err on the side of farther apart rather than having the belts be loose? This will be a completely sheet metal drivetrain by the way Any other advice about doing C-C belts would be appreciated |
Re: Center to Center with belts
When building exact c-to-c drivetrains with chains, we put the chain over the sprocket, then line the sprocket up with the bearing block, then skewer the whole thing with the shaft. When using belts I'd think the approach would be similar, though a bit more difficult because you need more tension in the belts.
We did GT2 5mm x 9mm belts this year with C-C + .005 in our west coast drive train and loved them.
http://25.media.tumblr.com/6a0f1b587...cgvo5_1280.jpg However we used tube and CNC milled them, down to probably +/- .003 tolerances. We never had an single issue after 2 regional. |
This thread has a lot of useful information on how to do exact c-c spacing with belts.
1. Do you mean you milled the GT2 pulleys? If so, can you provide some details on what is required to do such a thing. Are there specific CAD tools, special cutting tools, etc that make life easier? 2. It sounds like you didn't have any issues with belts skipping/ratcheting, even though 15mm belt sounds like a "safer choice" for a drivetrain. Using the 9mm did you drive it hard, go from full forward to full reverse, push much, etc without issues? |
#7
Take a look at the Andy Mark 2013 KOP drive train.
In the past we've built a tensioned belt setup and then last year we used the Andy Mark Setup. It is a excellent drive setup. Easy to assemble and maintain and we had no belt ratcheting whatsoever despite playing mostly defense. We were geared to 10'/sec , 6 wheel dropped with 4 CIMs. 6" kit wheels The width of the belts, the size of the pulleys and the dead axle make assembly easy. I was surprised to see so many 2013 kit bots in the Curie Finals. The Kit bot on Steroids is a excellent drive train. |
#8
Really happy with this drive. What I meant in my post was I CNC milled the bearing holes in the rails so that the C-C distance was a really tight tolerance. (I would think 1/32 off would be to much). However I did machine my own pulleys, more info: http://www.chiefdelphi.com/media/photos/38380 In short just a tiny (3/32th) square endmill + 3/8 alum plate + cnc. The pulley cad was downloaded from SDPSI and I used just my regular CAM software to come up with the tool path. We did not have any issues with skipping and ratcheting. And the people that have seen me drive can vouch we pushed the drive as hard as we could, with doing all the above. Also to test I pretty much rammed into a test wall and stalled the motors and the belts still didn't ratchet. |
#9
I used XL timing belts and pulleys from McMaster and the SDP-SI calculator and I would call it a very loose fit, but it never skipped. I would have liked the fit to have much less slop though.
#10
The industrial answer is to make the perimeter that encompasses the OD of each pulley and the tangents to those edges equal to the inner perimeter of the belt, so that it fits over all pulleys at the same time. Then, either cam one shaft into location (ie - slide) or use a cam-style idler roller for belt tensioning (cam followers work great for this).
Of course, if you don't want to have a separate tensioner and you want the shafts to be fixed in place, you can have one of the pulleys have either no flange or a removable flange. After all, you typically only need flanges on every other pulley. A really good resource for timing belt information is http://www.martinsprocket.com/2001/SecK.pdf#J2 It has center-to-center charts, rules of thumb, engineering calculations, and design criteria. |
#11
-Mihir Iyer |
#12
We use a worksheet to calculate C-C distances for axles driving chains or belts. This works really well without requiring tensioners for short runs (<=6"). Longer runs require tensioners or empirical determination. Link to worksheet below:
http://www.chiefdelphi.com/media/papers/2715 |
#14
Jesse |
#15
Just keep in mind that for FRC, your FoS or duty rating will probably be much lower than 1 (i.e., it can take more torque than what's on the table). Those belts are designed for hundreds of thousands of cycles, something they'll never see in FRC, so we can probably get away with more torque than they were designed for. Adam Heard probably has a more exact number, as he's built a lot of belts drivetrains before. |
