Go to Post You can't please all the people all the time. The rationale of "lots of people don't like it" is not a reason to stop doing it. - Karthik [more]
Unread 29-05-2013, 09:54
rhsphoenix rhsphoenix is offline
FRC #2224
rhsphoenix is an unknown quantity at this point
[help] Add joystick button to pneumatics bumper
Competitions are over for out team, but we are adding things to our robot for the sake of learning how the code works, etc.
We did not write the code for our robot and are trying to figure out how to add a joystick button that activates a cylinder. We already have one button on this joystick that activates a cylinder, so we just copy and pasted the code and tried to change the bumper relay, but the leds on the bumper don't react to the new code, so I'm prettysure we did something wrong.
Any help is much appreciated and I can give any info needed.
P.s: I already checked websites with labview examples . . .
ID:	14905  Click image for larger version
ID:	14906  Click image for larger version
Unread 29-05-2013, 10:15
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
Re: [help] Add joystick button to pneumatics bumper
In Begin.vi set Duel Solenoid 3-4's module to "Solenoid Module 1" like Duel Solenoid 1-2 is.
The "Solenoid Module 2" option is only used if you have two pneumatic bumpers. Presumably you only have one; I don't think that I've ever seen a team use two.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 29-05-2013, 13:10
FRC #2224
Okay, I made the correction. It's still not working though :/.
Unread 31-05-2013, 09:06
AGPapa's Avatar
AKA: Antonio Papa
FRC #5895
I am not the most experienced in double solenoids (we always use single); so I may be missing something obvious. It looks like your code should work.
Could there be a wiring error? The Double Solenoid is called "Dual Solenoid 3-4" but it uses Solenoids 7 and 8. Is it wired to 7 and 8?
Do the other functions of that joystick work? Is the other solenoid is working as it is supposed to?
Unread 31-05-2013, 09:29
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Odd as it may seem, when we program dual acting solenoids, we actually program them as two single acting solenoids and simply pair them together (think identical twins). We got the idea after having pnuematic trouble and turning to team 358's website for help. Below it the link. I would scroll down to "Double Solenoid Example" and "Double Solenoid Example - alternative implementation ". We've used the alternate style for years. The website also has a description of the mechanical pnematics set-up (along with almost everything else you could want to know about a robot) if you need to check your hardware.
http://team358.org/files/programming...2009-/LabVIEW/
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
