Go to Post I've been inspired for real engineering during the build season and on the playing field, but the inspiration I found in the pits is often for creative thinking and intuition. - artdutra04 [more]
Unread 25-06-2013, 22:42
1683cadder 1683cadder is offline
FRC #1683 (Techno Titans)
Team Role: CAD
1683cadder is on a distinguished road
Extruded Aluminum Frame Generator
I made this as a summer CAD project. This is designed to help teams that use extruded aluminum frames develop a frame in a few minutes rather than hours so that more time could be spent on designing other systems on the robot. This tool generates the entire metal frame for you including the bolts and nuts (provided that you use 1/4-20). What needs to be provided are the wheels, bearings, axles, hole tapping, and other attachments you need. Please provide feedback. Link for download
Key files:
  • extrudedaluminumframeparameters.xls -place where the parameters are edited.
  • extrudedaluminumframe.iam-the generated frame
  • extrudedaluminumframe2.iam- the same as above except organized in to sub assemblies.
  • extrudedaluminumframe.dwg- drawing displaying where the parameters go and shows how to assemble the frame.
  • extrudedaluminumframe-numericdimensions.dwg- drawings with dimensions rather than parameters. Does not show how to assemble the frame.
PS. Can I use this design during the FIRST season? If anyone is from the Duluth area of Georgia, can he tell me where a good place is to get parts machined (like CNC)?
Unread 26-06-2013, 19:32
smart1's Avatar
smart1 smart1 is offline
AKA: Kyle
FRC #0967 (Iron Lions)
smart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud of
Re: Extruded Aluminum Frame Generator
Is it bosch 20 series or 8020?
Who is this guy named We I keep hearing about, everybody says We will do that later but I haven't ever met him.
Unread 26-06-2013, 20:05
Team Role: CAD
Unfortunately, it is neither; it is aluminum square tubing.
Unread 26-06-2013, 20:14
EricH EricH is online now
Does it have a way to compute how much weld material you'll need? I'd say that 75-80% or more of teams who use square tubing weld it instead of bolting it. There are teams that bolt... but they're far outnumbered by the welded ones.
Regarding the legality of using this tool during the 2014 or other future build season, I would say that it falls into the same category as JVN's design calculator--it's a publicly available design aid, therefore, not regulated in any way by FIRST. Now, the designs that come from it would be illegal if not generated after Kickoff. (Also note: I'm making the assumption that the rules on timing and tools don't change next year. I could be very wrong.)
Unread 26-06-2013, 21:06
Team Role: CAD
No, but I could make an addition to the tool.
Thanks for clarifying the rule.
Unread 26-06-2013, 21:32
T^2 T^2 is offline
FRC #5499
Note: I haven't tested this yet.
1. Do you use gussets or internal blocks for bolting frame members together?
2. Is the frame generated by this accessible from another computer through a server such as Autodesk 360 without having the parameters on that computer?
3. How well does this work in SolidWorks?
Unread 26-06-2013, 22:17
Team Role: CAD
1. Internal blocks.
2. Hmmm, I'm not really sure. From my experience when you delete the linked spreadsheet from the part, the dimensions stay. I think you should be fine if you send the generated frame without the parameters.
3. I'm not sure how you can convert this type of project into solidworks without losing the ability to edit the parameters. Can someone tell me how?
