Go to Post Ive been chewing on my yellow food wristband every night since the team party on friday at UTC. Every day it tastes better and better...almost as good as the food. Anyone else think so? - Sscamatt [more]
Unread 27-06-2013, 02:19
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Retaining Ring Groove Tool
What does everyone use for cutting retaining ring grooves in shafts? Specifically, I'm looking for something to provide a properly toleranced groove for a 1/2" shaft, which is .039" wide x .468" in diam. All the cutting tools we own are much wider than this. I know you can custom grind your own tools from HSS but I have no experience with this. Something off the shelf would be preferred.
Unread 27-06-2013, 02:52
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Retaining Ring Groove Tool
Big Kaiser Thinbit SGI039D5 for aluminum SGI039D2 for ferrous metals.
You will need p/n SFT12L for the holder (you can select a different shank size if necessary)
Western Tool and Supply in Portland carries them. You can probably find other local distributors.
2001-2004: Team 100
2006-Present: Team 254
Unread 27-06-2013, 07:17
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
It's easy to grind a piece of HSS cutter stock to do the job. Keep your micrometer caliper handy and check the size often. The narrow piece only needs to be about 1/4" long. If you screw it up, grind it off and start over. I made one up yesterday by grinding down a piece of .100 parting tool because it was quicker than finding the one I made during build which is double ended - one for 1/2 and the other for 3/8. It took less than 5 minutes and when I was done, I just ground it back to square again. A LOT cheaper than buying a special holder and cutter.
Unread 27-06-2013, 09:08
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Although it doesn't discuss exactly how to cut a retainer groove. "How to Run A Lathe" by South Bend Lathe Works is a good basic how to on operating a lathe. Originally published in early 1900s & updated through the years. Early versions can be found as a PDF download or ordered cheaply as a reprint. Along with a Machinery Handbook, it enough to do anything you can do (which is a lot) with a small lathe.
It has a section on grinding bits.
Unread 27-06-2013, 11:52
Cory's Avatar
AKA: Cory McBride
I view grinding tools as a stopgap measure if you absolutely need to get it done now and you can't go buy the tool you need.
It's so much nicer working with inserted grooving tools, especially in small sizes.
2001-2004: Team 100
Unread 27-06-2013, 11:54
AdamHeard's Avatar
Lead Mentor
Agreed.
Even properly ground, the ground tool just doesn't last as long as the insert tool.
We do a lot of snap rings, so this saves us a good deal of time.
Unread 27-06-2013, 19:11
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Agreed.
Also, our kids break a lot of the grooving inserts by running them sideways into the workpiece. Much easier to replace them than to grind a new tool.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 28-06-2013, 00:15
craigboez's Avatar
Mechanical Engineer
Thanks Cory, this is perfect. What do you use for cutting fluid with these (or do you cut dry)?
Unread 28-06-2013, 02:05
Cory's Avatar
AKA: Cory McBride
The amount of material removed is so small that there's not much need for cutting fluid.
2001-2004: Team 100
Unread 27-06-2013, 12:29
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
http://www.mscdirect.com/browse/Turn...roovin g+tool
MSC Direct is a good resource for tooling. There may even be a branch local to you so you don't have to pay shipping. The local branch *might* even be willing to sponsor your team ...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 27-06-2013, 13:15
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
We use a Nikcole Mini-Systems grooving tool and it works well. Enco sells it along with a page full of cutter inserts. Just saw this link through amazon:
http://www.amazon.com/Nikcole-Mini-G.../dp/B004KAET5I
Unread 27-06-2013, 17:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We do all ours with a HSS blank that we grind. It's never been a problem. This past season, we started doing the ones we could in a vertical collet holder in the CNC using a slitting saw to go around it. Came out great.
