IRI Teams with a spare P60 gearbox?
Do any teams going to IRI happen to have an extra BaneBots P60 16:1 gearbox for 500 series motors, either with an unattached pinion or a legal motor already mounted?
We realized when getting our packing list together this weekend that we are out of spares. Worst case scenario, we will be able to run our collector with a 26:1 gearbox in the case of a failure (which we have found to be quite common with these gearboxes), but a 16:1 would be preferable. We are currently running it with a RS-550, but most of the legal motors that can mount would do. Based on our experience when ordering from BaneBots, we do not think there is any way they would get it to us in time. |
Re: IRI Teams with a spare P60 gearbox?
I will check our gearbox box (heh... gearboxbox) and try to bring one.
We have lots of 4:1 Banebots stuff packed with us. We should be able to help you out. I think I have a 2 stage housing but I can't say for sure.
At a minimum this should let them make a 20.4:1 gearbox (swap a 4:1 stage w/ the 26:1 gearbox) right?
Oh, right. Forgot they're the same housing. I'm sure we have two 4:1 stages, so it should be good.
#7
I believe we have a 20:1 with a 550 mounted on it. If so I'll have our team toss it in with the rest of the stuff in case you need it.
#8
Found it, it will be packed up with our stuff. Stop by our Pit Thursday or Friday.
#9
Thanks everyone! We will be sure to stop by you pits on Thursday or Friday, Allen.
Adam, the only complication I can think of with constructing a 20.4:1 from available parts is replacing the sun gear from the carrier to match the "wrong" size of the next stage, but it seems doable. Certainly wouldn't be a bad way to go if we had time and were stuck between a rock and a hard place. Anyone have experience with that on BB planetaries? See everyone in a few more days! |
#10
One of our mentors looked at one of the failures and his immediate reaction was that there was no way the gears were cold-rolled, they must have been powder sintered because of the way there was metal powder everywhere in the gearbox. The cross section of the exposed inner surfaces of the gears also appears very non-uniform and grainy. I've been doing research on other options for planetary gearboxes and we will likely be working with the VexPro Versa Planetaries in the future. |
#12
To transition between a 5:1 and 4:1 stage, you need a special carrier/sun gear that goes from the 5:1 planet spacing to the 4:1 sun gear size. There are actually 5 different carriers for the P60 gear box.
- 4:1 planets to output (required for last stage) - 5:1 planets to output (required for last stage) - 4:1 planets to 4:1 sun - 5:1 planets to 5:1 sun - 5:1 planets to 4:1 sun http://banebots.com/c/P60P-CP Incidentally, if you have mixed 4:1 and 5:1 stages, all the 5:1 stages must appear first in the gear box (nearest the motor), meaning you need to have an input motor with the 5:1 sun gear. Last edited by MechEng83 : 16-07-2013 at 15:21. Reason: More info |
