Go to Post Everyone is reading way too much into this. The game piece is clearly a bunch of Opahs this year. Problem solved, case closed. Start designing your fish handling robots now. - Ryan Dognaux [more]
Unread 17-07-2013, 10:51
wre136's Avatar
wre136 wre136 is offline
AKA: Will Edds
FRC #2461 (The METAL-SKINS)
wre136 is an unknown quantity at this point
Question Tutorials with I2C port on Digitial Side Car for US First Robotics?
Are there any tutorials for using the I2C port on the Digital Side Card and LabView? I've always seen that port but not sure how to connect to it, how to use it or what to use it for.
Unread 18-07-2013, 09:12
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Tutorials with I2C port on Digitial Side Car for US First Robotics?
I'd suggest the NI Example Finder. You can launch it from the Support tab of the LabVIEW Getting Started Window, or from within a VI choose Help>>Find Examples...
It will open to the FC Robotics folder and within that you'll see an I2C folder. Along with example code, the LabVIEW examples also show you how to wire sensor and actuator hardware.
Doug Norman
