Go to Post You don't always get what you pay for, but you hardly ever get what you don't pay for. - MrForbes [more]
Thread Tools Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
Unread 25-07-2013, 19:22
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
Battery powered raspberry pi
This year, we had problems with the unstable power supply for our onboard raspberry pi. I'm a little stuck as to how to solve that:
Option a) get a battery for the raspberry pi -> illegal under R34 because it is not an integral battery. Can I get around this rule, assuming it doesn't change?
Option b) use a laptop -> laptops are usually comparatively heavy and big. Does anyone know a lightweight, cheap laptop with at least 2 USB ports and Ethernet? [a 3rd USB port for an Ethernet dongle is fine]
Option c) somehow guarantee the availability of 1 amp for the raspberry pi?
Option d) can anyone else think of another option?
Thanks so much for any help you can give me!
Unread 25-07-2013, 19:26
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Battery powered raspberry pi
What did you have as a power supply for the pi?
For option b, look at SBCs (atom computers on a single board with, well, everything). Suggestion: http://www.geeky-gadgets.com/wp-cont...abyte-Brix.jpg
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 25-07-2013, 20:58
ericsims ericsims is offline
FRC #0178
ericsims is an unknown quantity at this point
I would try and use a circuit similar to this:
http://schematiccircuit.files.wordpr...ing-lm7805.jpg
That is what out team did to make our onboard PI work. Have you tried anything similar to that yet?
Unread 26-07-2013, 21:48
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
My advice is a step-up switching regulator like in the FIRST PDB.
Going into a step-down switching regulator sort of like inside the cRIO.
National Semiconductor makes parts that will switch battery voltage up to roughly 20V.
Obviously because look at the cRIO input voltage.
National Semiconductor also makes parts that will switch roughly 20V down to 5V.
Each stage of regulation is both a noise filter and complements the other.
If you switch up to 20V and the battery caves to 8V the 20V suffers.
However the next stage just needs to get 5V so that 20V quality issue is damped.
Each stage will be probably about 87% to 95% efficient with switching regulation.
On the other hand a 7805 as pictured will remove the excess energy as heat.
If the battery is 14.3V depending on the current enough heat for a heatsink.
Sure you can get a TO3 metal can version of the 7805 or make an external pass transistor but it still just burns energy off as heat.
If you do build that 7805 circuit you should install blocking and bypass silicon diodes.
Unread 29-07-2013, 13:11
Kyle R Kyle R is offline
FRC #4246 (Resurrected Robotics)
Kyle R is an unknown quantity at this point
We have had pretty good luck with using one of these (http://www.andymark.com/product-p/am-0899.htm) to power an onboard RPi. It is the switching power supply that comes in the KOP for the wireless bridge but it works great for powering the RPi. Another bonus is you probable have one left over from a previous year.
Unread 29-07-2013, 13:21
What power supply did you use last year?
Unread 06-08-2013, 11:56
techhelpbb's Avatar
Has anyone considered using one of these for your power needs from the robot battery?
http://www.dfrobot.com/index.php?rou...product_id=752
(That is the source in China)
http://www.robotshop.com/productinfo...222&lang=en-US
(They carry their products here in the U.S. and Canada)
I have several Chinese manufactured PCB with National Semiconductor regulators and when I have some time (probably in the next week or so) I will power them up and test them at 1A from 7VDC to 15VDC.
I stumbled across that because I bought one of their Relay Shield V1.2 to update my ever growing pile of Arduino swag.
Unread 06-08-2013, 14:17
ohrly?'s Avatar
Griffin Alum
AKA: Colin Poler
We used a second 12v-5v power converter (http://www.andymark.com/product-p/am-0899.htm). It was a problematic because if the compressor and shooter motors were both running at the same time, there wouldn't be enough power left for anything else.
I realize now that was because we chose our gear ratios terribly and the shooter motors were running very inefficiently, but all the same I wanted to try to isolate the RPi's power from the rest of the robot so it wouldn't cut out.
Unread 06-08-2013, 14:35
techhelpbb's Avatar
The problem ultimately will be that you can't really store energy for a protracted period with the FRC rule limitations on custom circuits.
The allowance of a laptop and it's battery I think were more intended to allow teams to not have to make more electronic modifications to the laptops which usually come neatly packaged.
I suspect if you put any largish capacitor or battery on the robot within a custom circuit specifically to provide 0.X seconds of storage you'll start to have issues getting through inspection.
I would be interested to know if anyone has managed to pull off a storage capacitor or battery in a custom circuit and made it through an actual FRC inspection. You can get high Farad value capacitors at 5V that would easily provide a robust filter against short drops in the battery. However those capacitors do not generally discharge themselves and for a relatively short period of time after a power off power will remain. It is possible to make a discharge circuit for a capacitor after power off but I'm not even sure the capacitors or auxillary battery would be allowed.
Unread 06-08-2013, 16:02
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
So I guess this is out of the question?
Unread 06-08-2013, 16:13
techhelpbb's Avatar
LOL I actually have a 3.5F capacitor for automotive electronics on my test robot frame at home. It basically comes with it's own welder.
I was thinking something more like this:
http://www.karlssonrobotics.com/cart...Fcef4Aodwy0AYQ
I love that datasheet.
For tolerance it lists: -20%〜+80%
So I guess it's perfectly okay to send out a 15F capacitor instead of a 10F capacitor?
Might make the RC time constants *just a bit* longer.
BTW: With a capacitance this large one really needs to consider the currents that will flow if that capacitance is entirely discharged and someone connects a power source to it. Luckily with control system boot and robot setup times of at least 1 minute there's time to charge it slowly. Though I still doubt it is legal in FRC.
Unread 06-08-2013, 17:04
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
How about a BEC used for RC cars and planes?
http://www.graysonhobby.com/catalog/3ampbec-p-786.html
2015 Newton Semi-Finalist (3130, 2468, 3310, 537)
2015 Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360)
2014 Colorado Regional Winner (1138, 3310, 2543)
2013 Texas Robot Roundup Winner (3310, 624, 2848)
2013 Archimedes Semi-Finalist (126, 3310, 1756)
2013 Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
Unread 07-08-2013, 16:18
foote stepped in
AKA: E. Foote
FRC #0868
I suspect that tolerance is more closely related to ambient temperature than their manufacturing capabilities.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 07-08-2013, 16:30
techhelpbb's Avatar
Well Digikey sells the Nichicon super capacitors and they list +/-20% as does Murata.
BTW if you look through the high end capacitance in the Digikey component search it's pretty interesting.
A few thousand Farad capacitor anyone?
Unread 07-08-2013, 17:08
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
maybe I read the rules incorrectly, but wasn't there an exemption on battery power when in came to on board computing? Laptops can use a battery. what's the significant difference in that RPI and a laptop?
