Go to Post Whether or not your team has the technical mentors, as long as your kids are still inspired by the adult technical mentors of other teams, and get the picture that we're trying to portray in this program, the best that you can do is the best you can do. Do it, and be proud of your results. - Beth Sweet [more]
Unread 22-08-2013, 19:17
Nathan4567a's Avatar
Nathan4567a Nathan4567a is offline
Circuit Master
AKA: Nathan Lerner
FRC #2587 (Discobots)
Nathan4567a will become famous soon enoughNathan4567a will become famous soon enough
Live Stream Score Overlay
Ok lets assume that everything works perfectly. The camera interfaces with the computer perfectly, OBS works perfectly, everything is perfect. How would I get the field score overlay from the FRC field onto the live stream? I am just talking the hardware side. Ho do I get the overlay onto my computer so I can put it on the live stream?
Computer-Builder.Photographer.Videographer.Nerd
Unread 22-08-2013, 21:47
Circuit Master
AKA: Nathan Lerner
Re: Live Stream Score Overlay
Here is the info I found. I have been trying to figure this out for some time, but finally found the info I needed.
http://www.andymark.com/product-p/offseasonfield.htm
Unread 22-08-2013, 22:52
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
If I remember correctly the FMS PC outputs the score display in composite or VGA, so look into a capture card. You can crop out where the camera feed would normally be on the score display and overlay just the score info onto a nice HD video feed.
EDIT: not sure if OBS supports cropping. Chroma key might be possible instead? Xsplit supports either method.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
